Posted May 18, 201311 yr comment_423700 HiHave seen several posts contained in the forums that discuss a choke bracket to remount the choke lever onto the transmission tunnel. The retro-fit item available on ebay 240z choke lever bracket in eBay Motors | eBayworks for the 240z only - I have an early '74 260Z & the ebay bracket will not line up. Anyone aware of a similar 260z solution for this issue - trying to avoid fabricating a bracket myself if there is already a working design out there.Thanks Rich. Link to comment https://www.classiczcars.com/forums/topic/46574-260z-choke-lever-mount-issue/ Share on other sites More sharing options...
May 18, 201311 yr comment_423710 It does say you can use the earlier choke cables on your 260. Finding them would be the only problem. I wonder how much they are off. I did put this in my '73. The dimensions are wrong on the instruction sheet, so whoever buys this should be aware. It would be much easier with tech screws as well, no need to pre drill. Link to comment https://www.classiczcars.com/forums/topic/46574-260z-choke-lever-mount-issue/#findComment-423710 Share on other sites More sharing options...
May 18, 201311 yr Author comment_423712 Yeah - I did see the choke cabel comment, but as you say, finding good ones in working order can be a pain. I was hoping the 240Z bracket could be easily modified, but seems like that may not be the case Link to comment https://www.classiczcars.com/forums/topic/46574-260z-choke-lever-mount-issue/#findComment-423712 Share on other sites More sharing options...
May 19, 201311 yr comment_423749 I have an early 1974 260z and have this bracket mounted and working in the car with the stock cablesChoke Cable Lever Bracket - Datsun 240Z | Acadiana Sports Car Orphanage - Official StoreIt looks identical but when i bought it the description was different:1 x Choke Cable Lever Bracket - Datsun 240Z/260Z - $28.95 SKU: AS-S30-CBKI didnt have any problems installing it Link to comment https://www.classiczcars.com/forums/topic/46574-260z-choke-lever-mount-issue/#findComment-423749 Share on other sites More sharing options...
