Posted May 19, 201311 yr comment_423722 Alright guys, I left work and the car was already warmed up (1978 280Z) the temp was about a quarter of the way to half way on the gauge. I stepped into it and then when I got off of it the temp gauge suddenly shot down and stayed there. I pulled over checked the wires and everything seems to still be connected and in tact. Any ideas to what has happened? Thanks in advance guys. Link to comment https://www.classiczcars.com/forums/topic/46578-coolant-temp-sensor-quit-working/ Share on other sites More sharing options...
May 19, 201311 yr comment_423728 sender unit gave way, or corrosion at the connector, bad connection, i think Link to comment https://www.classiczcars.com/forums/topic/46578-coolant-temp-sensor-quit-working/#findComment-423728 Share on other sites More sharing options...
