June 6, 201311 yr comment_424995 yes, thank you very much - very helpful. when i said flattening the rocker, i meant bending the tabs down so they are closer to the contacts. it seems like they're just not quite touching when the unit is assembled. will post the results!thanksKen Link to comment https://www.classiczcars.com/forums/topic/46592-need-some-turn-signal-help/?&page=3#findComment-424995 Share on other sites More sharing options...
June 10, 201311 yr comment_425219 ok, i've gotten into the switch a few times, bent down the contact tabs, etc. the problem i'm having is the slop in the nylon block that engages the pin that sticks out from the switch box - the nylon block inside the switch box just does not move far enough to push down the contacts. i pulled apart the switch and removed the big spring ( see image ) everything works fine. but i'm assuming that big spring kicks the blinker back to zero after the turn? Link to comment https://www.classiczcars.com/forums/topic/46592-need-some-turn-signal-help/?&page=3#findComment-425219 Share on other sites More sharing options...
June 10, 201311 yr comment_425220 update - turns out the big spring isnt the problem, switch works OK with spring in place. looks like the slots that the pins from the return arms slide in are preventing the switch from moving far enough. should i lengthen the slots? Link to comment https://www.classiczcars.com/forums/topic/46592-need-some-turn-signal-help/?&page=3#findComment-425220 Share on other sites More sharing options...
June 10, 201311 yr comment_425223 I would have to take a look at my stock to see exactly what could be blocking the action of the switch. Link to comment https://www.classiczcars.com/forums/topic/46592-need-some-turn-signal-help/?&page=3#findComment-425223 Share on other sites More sharing options...
June 15, 201311 yr comment_425709 Thanks for everybody's input, i gave up and bought a new assy on ebay!Ken Link to comment https://www.classiczcars.com/forums/topic/46592-need-some-turn-signal-help/?&page=3#findComment-425709 Share on other sites More sharing options...
