Posted May 21, 201311 yr comment_423843 I purchased a motorhome and just wanted to know for sure in can flat tow my z. :paranoid: if so any fluids in driveline suggested. trans and diff. please help. I do not want to destroy a z over trying without knowing. Link to comment https://www.classiczcars.com/forums/topic/46597-1978-5-speed-towing/ Share on other sites More sharing options...
May 21, 201311 yr comment_423848 A stick-shift Z-car left in neutral should tow just fine. Link to comment https://www.classiczcars.com/forums/topic/46597-1978-5-speed-towing/#findComment-423848 Share on other sites More sharing options...
May 22, 201311 yr comment_423975 You might consider making your Z a trailer queen rather than dragging it around. Link to comment https://www.classiczcars.com/forums/topic/46597-1978-5-speed-towing/#findComment-423975 Share on other sites More sharing options...
May 22, 201311 yr comment_423981 Or new RV Link to comment https://www.classiczcars.com/forums/topic/46597-1978-5-speed-towing/#findComment-423981 Share on other sites More sharing options...
May 22, 201311 yr comment_423982 A few years back had to have the 240Z towed, it broke the ignition switch. Searched the forums here and found the switch can't be in the lock position, use acc. They say pull a fuse for long tow - don't remember which one. After some calls and faxing them copy of a page from the manual, they finally paid half the cost of the switch.Guess it depends on how it's towed. Link to comment https://www.classiczcars.com/forums/topic/46597-1978-5-speed-towing/#findComment-423982 Share on other sites More sharing options...
May 22, 201311 yr Author comment_423996 i like black gold man's idea.,. i dont have room at my residence to store car trailer.just wanted to know if it will damage drivline. Link to comment https://www.classiczcars.com/forums/topic/46597-1978-5-speed-towing/#findComment-423996 Share on other sites More sharing options...
May 23, 201311 yr comment_424008 Or new RV Even with air over hydraulic suspension and 6" of lift in the cubby I'll bet that thing's hell getting over speedbumps. Link to comment https://www.classiczcars.com/forums/topic/46597-1978-5-speed-towing/#findComment-424008 Share on other sites More sharing options...
