Posted May 27, 201311 yr comment_424227 Does anyone know if it is possible to replace the studs on the rear strut mount? P.O. stripped one out when he installed his POS homemade strut brace. Link to comment https://www.classiczcars.com/forums/topic/46640-rear-strut-mount-insulator/ Share on other sites More sharing options...
May 27, 201311 yr comment_424251 they can be rethreaded. Link to comment https://www.classiczcars.com/forums/topic/46640-rear-strut-mount-insulator/#findComment-424251 Share on other sites More sharing options...
May 27, 201311 yr comment_424253 Run a 10x1.25 die over that and see how it cleans up. Lots of lube while you do it, and careful when starting. I'm not very close, but I have a couple of those tall 280 insulators available if you get stuck. z240@shaw.ca if you need one. Link to comment https://www.classiczcars.com/forums/topic/46640-rear-strut-mount-insulator/#findComment-424253 Share on other sites More sharing options...
May 27, 201311 yr comment_424256 You could also cut new threads a size smaller. But then you'll be the "idiot PO" if you ever sell the car. I would still do it if it was my car. Maybe even use standard thread size for stronger effect.I think that there's about 5 mm of extra stud when they're installed. You might not need the messed up part. Link to comment https://www.classiczcars.com/forums/topic/46640-rear-strut-mount-insulator/#findComment-424256 Share on other sites More sharing options...
May 27, 201311 yr comment_424263 The threads look pretty stuffed. The PO dun a good job making it useless.I would run a M8 x 1.5 die over it and buy a set of think machine washers. If you dont have a metric stock and die set you could take it to a machine shop and get them todo it.Chas Link to comment https://www.classiczcars.com/forums/topic/46640-rear-strut-mount-insulator/#findComment-424263 Share on other sites More sharing options...
May 28, 201311 yr Author comment_424280 Thanks for the replies!! It's hard to tell by the picture, but the first 5 to 6 threads are pretty much gone. Come to find out it was a SAE nut that was forced on (been finding that same issue all over the car). Guess I'll start off with trying to rethread it, or even try going down to a M8 x 1.5........ I'm not very close, but I have a couple of those tall 280 insulators available if you get stuck. z240@shaw.ca if you need one.If all else fails....I'll be giving you a shout!!Thanks Link to comment https://www.classiczcars.com/forums/topic/46640-rear-strut-mount-insulator/#findComment-424280 Share on other sites More sharing options...
