Posted May 28, 201311 yr comment_424303 After continually fiddling with my SU's I've created a fairly inexpensive Sightglass for my carburetor float bowls. My device will allow me to see what the floats are set at and ensure that the carb gross fuel mixture setting is correct. Then I'm able to dial in the fine mixture setting with the adjustment knobs on the nozzle to get back to factory specs. Would there be interest from any members in a set (allows you to see levels in both carbs at the same time)? I'd be willing to provide 2 sightglasses with instructions for $15 including shipping anywhere in the US. PM me if you're interested and I can provide more detail. Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/ Share on other sites More sharing options...
May 28, 201311 yr comment_424304 Dave: Excellent idea. I've made my own, and thought how I'de always wanted to offer the service, but well, you know... Glad you're taking it on. Many will benefit. One comment. I've been twiddling with several peoples SU's recently, and I've been using the standard 23mm down from the top of the float bowl measurement. I looked at the FSM this Morning to find the nifty picture you attached and noticed something about the reference for the "top" of the 23mm measurement that I didn't realize. I seems I've been doing this wrong. I've been measuring down from top of the cover at the gasket, not the internal "roof" as it were as the FSM drawing indicates. I think its only a 1mm or so, but still. Might want to amend your drawing to reflect this too. I'm going to review a few of the posts about this (there are many) and see what everyone else has been doing. Jim Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424304 Share on other sites More sharing options...
May 28, 201311 yr Author comment_424307 Great point, Jim. I actually just grabbed this pic to illustrate what we were trying to accomplish. I'm still formalizing my instruction manual based on my learnings throughout the years. The funny thing is I was running at about 15mm of fuel and having tons of issues, raising it back up improved the drivability and performance once tuned properly. Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424307 Share on other sites More sharing options...
May 28, 201311 yr comment_424310 I found the drawing you used, its from Blue, in this post; http://www.classiczcars.com/forums/su-carb-technical-articles/44010-setting-fuel-level.html #8 Right next to it, he has the FSM drawing I used, showing the top reference at the 'roof' of the cover, but his drawing has it at the gasket.... Now we'll have to convince him to make an amendment to that thread. !! He's never going to let me forget this.... Now we need a better way to improve the tedious and gasket wasting method of endlessly adjusting float levels... Edited May 28, 201311 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424310 Share on other sites More sharing options...
May 28, 201311 yr comment_424323 Now we need a better way to improve the tedious and gasket wasting method of endlessly adjusting float levels... Sounds like you want a set of OER triples. Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424323 Share on other sites More sharing options...
May 28, 201311 yr comment_424328 Great idea! I know from experience that getting the float level correct on both carbs is the essential first step to adjusting the mixture in these carbs. I've done this using a clear vinyl tube on the nozzle-tube nipple, but that takes fiddling since you obviously can't check it with the engine running. Can I assume that you are using the drain plug on the bowls? If so, remember that some of the early Series 1 cars came with SUs that had no float drains. Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424328 Share on other sites More sharing options...
May 28, 201311 yr Author comment_424331 I created this tool out of necessity since now that gross jets are no longer available, its a pain to accurately set the float level on the bench while rebuilding the carb's. The approach I took is for the tool to used temporarily while checking float levels; once set, the sightglass is removed. I pull the fuel hose from the float bowl & connect my sightglass to the nipple. Its preformed and graduated to allow the user to easily see how high the fuel level should be. Then a couple cranks of the engine (coil wire unplugged & trans in neutral), the sightglass fills up. Then it becomes a game of opening up the float bowl lid, bending the tang and re-filling the bowls. Once set the floats should be good for quite a long duration, thus the reason I didn't invest in drain plug bungles. I actually prefer running this test without the engine running. Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424331 Share on other sites More sharing options...
May 28, 201311 yr comment_424332 I'm interested. I've been fighting with mine and need to redo them very soon.BTW, is there a better way to deal with the bowl gaskets? They work great the first time and then they curl and get hard to line up. Can we glue them to the lids? Is there a better gasket material? I hate these things. Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424332 Share on other sites More sharing options...
May 28, 201311 yr comment_424333 The approach I took is for the tool to used temporarily while checking float levels; once set, the sightglass is removed. I pull the fuel hose from the float bowl & connect my sightglass to the nipple. Its preformed and graduated to allow the user to easily see how high the fuel level should be. Then a couple cranks of the engine (coil wire unplugged & trans in neutral), the sightglass fills up. Then it becomes a game of opening up the float bowl lid, bending the tang and re-filling the bowls.Very good. That's exactly how I did mine, except my tubes weren't calibrated. This will work. Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424333 Share on other sites More sharing options...
May 29, 201311 yr comment_424371 Dave, Got a silly question about exactly where you connect you site glass. You say you remove the fuel hose from the bowl and connect to the nipple. I'm hoping you mean vent hose. I'de also really like to see a picture of this contraption of yours and how it measures fuel level from the vent line nipple. I can see a probe that touches the top of the float to give you an indication, but that's not the top of the fuel level. Please help the eternally confused. Thanks Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424371 Share on other sites More sharing options...
May 29, 201311 yr comment_424379 Here is my tool: I tee'd 3 clear hoses, two of these carry fuel the normal path from the bottom of the fuel bowl to the bottom of the jet. The third "fuel level" hose is open at one end and rises up from the "T". I have a 23mm (or other ) mark on the outer fuel bowl wall and hold the "fuel level" hose against it while cranking with the plugs out. Once the fuel level in the hose is noted against the 23mm mark, I tip the "fuel level" hose out into a cup and drain a bit more fuel from the fuel bowl then dump the cup into the fuel tank. The float level can then be adjusted at the tang and the level check repeated Ad nauseam until correct. Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424379 Share on other sites More sharing options...
May 29, 201311 yr Author comment_424380 Thanks to gravity and atmospheric pressure, water (and other fluids including gas) seeks its own level. What this means is if you take a tube and hold it in a “U†shape and fill it partially with water, no matter how high you hold one end of the tube, the water will be the same height on both sides. This is the basic function of the sight glass. The level of gas shown in the sight glass is the same height as the fuel in the float bowl. My approach is to pull the fuel line from the bottom of the floatbowl. Link to comment https://www.classiczcars.com/forums/topic/46649-su-sightglasses-available-see-fuel-bowl-levels/#findComment-424380 Share on other sites More sharing options...
