Ok. I know we didn't get 280Z turbos in Australia.
What about 280ZX turbos?
Did we get any of them?
Were they even made?
If they were available in Japan, I guess there may be a 3 or 4 somewhere in Perth due to the secondhand imports we got.
How different are the engines or are they the same?
Could I use a turbo diesel block from a patrol and a petrol head?
Did they make turbo diesel patrols?
Or should I just put a RB series motor in?
https://www.classiczcars.com/forums/topic/4665-l28-turbos-in-australia/
There was no 280Z turbo.
The 280ZX turbo was US-only.
However....
there were a number of dealer-fitted turbo kits sold in AUS
(an HKS kit was used).
If you plan on making a L-turbo you can keep it pretty much stock, except shave the pistons 0.015" (or buy new ones with a pin 1mm higher). Get a fabricated exhaust manifold, bigger injectors & an aftermarket ECU (don't forget an intercooler).
I'm making 220HP from a home-built non-decompressed L28 with a T3 on it. Yes, it's reliable - 70,000km so far. Boost is only 6-7psi though due to the CR still being 8.4:1, if you lowered the CR to ~8:1 you would be able to run ~12psi. (this is how much my original L24 turbo in my Z ran - that was ~250HP).
I believe the Patrols were available with an LD28T form memory, but it's not easy finding one.
RB is pretty easy, but L-power is easy too if you want to keep the original engine family in the car. Look at Simon de-Groot's car...(which I would post the URL to, but It appears that his page is no longer on the UNQ website :( )
His car was featured in Zoom a few months back, it's producing ~220kW at the wheels now from an L28 Turbo setup.
there was actually a L28 engine for sale in the trading post last week.
-----------L28 TURBO MOTOR recent rebuild F54 block, P90 head polished aluminium turbo rocker cover, comes with 5 speed manual with 400hp brass button clutch. will seperate. EC $1850ono (03)97890151 graedat@optushome.com.au Langwarrin ---------
sounds interesting..if i knew where langwarrin was!
