Posted June 6, 201311 yr comment_425055 The time has come for me to replace my springs. MSA only has the progressive rate Eibach speings.These sound good but I have seen some threads that note problems with these progressive springs. Both ride height and that the top coils fully compress at rest...so why have them?Any info or feedback you may have will be welcome.Thanks Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/ Share on other sites More sharing options...
June 6, 201311 yr comment_425058 I guess it depends on what you are looking for in a spring. I had the Tokico’s on my yellow Z and they just about rattled my teeth loose, too stiff for daily driving. I switched over to the Eibach’s and really like those. I did cut 1.5 coils from the front springs to get the car to sit level. I am still running the Tokico 5 way adjustable at all 4 corners, with at the number 2 setting.. Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-425058 Share on other sites More sharing options...
June 7, 201311 yr comment_425069 Same here. Had to cut over 1 coil from the Eibach's to get her to sit level, but the springs have a good feel. Just don't go with the Tokico Blue shocks. While not bad, I've found them a be a bit too harsh for daily / weekend driving. Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-425069 Share on other sites More sharing options...
June 16, 201311 yr comment_425717 i went with the eibachs and blue tokico's. on my 72 240I am happy with the ride and handling improvements. one thing however, I found also that the ride height in the rear was a little lower than the front.Personally, i kinda like that look. with the right pair of rims and rubber I find it gives the car a good stable appearance.just recently, i added a thicker front and new rear sway bar. It seems to have helped with the ride height a little bit.handles way better now also. just my .02$i would recommend the eibachs and blue tokico's without hesitation. Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-425717 Share on other sites More sharing options...
June 16, 201311 yr comment_425744 I have the popular MSA Eibach-Tokiko combination installed. The car sits slightly lower, and sits evenly front-to-rear. The ride is slightly stiffer, as expected, but I am used to that, as I used to spend hours on my bike, with it's 180 PSI tyres and stiff steel frame. You just gotta remember that the car will shake more, so pick your roads carefully, and try not to keep anything that's vibration-senstive on the dash, or stuck to the windscreen. Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-425744 Share on other sites More sharing options...
June 19, 201311 yr comment_425982 I was using Tokiko Illuminas and Tokiko springs last year on my 1970 and found it a bit jarring but the PO had removed the bump stops so maybe that was the problem. Over the winter I installed bump stops and Eibach springs, I haven't driven an inch yet due to a problem I hope to have resolved soon but with the Eibach springs the front does sit an inch higher than the back, although the whole car does sit much lower than stock.I hope I won't have to cut the front springs as the travel between the top of the shock and bottom of the bump stop is only 1.75"Pacemakr, so you have the blues, one of these days when we get both of our cars together maybe we can trade rides and then post a write up on the differences between them? Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-425982 Share on other sites More sharing options...
June 24, 201311 yr comment_426223 How are you guys measuring ride height? Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-426223 Share on other sites More sharing options...
June 24, 201311 yr comment_426224 I'm running the tokico kit (springs + struts) and couldn't be happier. The ride is very good, but I'm running stock steel rims right now, once I go low profile I'm guessing it will get a little rougher as a daily driver.Dave's 1972 Datsun 240z: Suspension Rebuild Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-426224 Share on other sites More sharing options...
June 25, 201311 yr comment_426275 How are you guys measuring ride height?John, I'm measuring from the top of the wheel arch on the fender to the ground using the same wheel/tire combo. Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-426275 Share on other sites More sharing options...
July 2, 201311 yr comment_426790 Finally got 100 miles on the new suspension system and the heights have evened out, 3 season old Tokiko Illumina shocks,New Eibach springs and all other wearable suspension parts are also new. Measuring from the top of the wheel arch my heights are,driver front - 26.125"driver rear - 26"passenger front - 26.250"passenger rear - 25.5"So my "1inch taller in the front" isn't so cut and dry as it was. The passenger rear has me a little concerned. Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-426790 Share on other sites More sharing options...
August 12, 201311 yr comment_429589 What wheel/tire combos are people with Tokico springs/struts running? I'd prefer to avoid tire rub in the rear, so any suggestions would be appreciated! Thanks. Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-429589 Share on other sites More sharing options...
August 12, 201311 yr comment_429591 16X7" Wheels with 205 55 16" tires. I love the Eibachs with either Tokico Blues or Illuminas ( I have both and would recommend either). Edited August 12, 201311 yr by Diseazd Link to comment https://www.classiczcars.com/forums/topic/46710-springseibach-oor-tokiko-or-what/#findComment-429591 Share on other sites More sharing options...
