Posted June 11, 201311 yr comment_425319 Could I get one of you guys to take a pic of your overhead retractable seat belt mount? The area above and to the back of the side windows. My interior panels have been covered and I'm not sure exactly where the seat beat anchors mounted. (been to long since I took it apart)ThanksBryan Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/ Share on other sites More sharing options...
June 13, 201311 yr Author comment_425487 Any 75 Owners? Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425487 Share on other sites More sharing options...
June 13, 201311 yr comment_425496 Try the 1976 Body chapter. The 1975 chapter is missing, but 76 should be the same.Index of /FSM/280z Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425496 Share on other sites More sharing options...
June 13, 201311 yr Author comment_425531 Thanks Zed, I have the 75 FSM but it doesn't really pinpoint where they mount. I'm pretty sure I know, I just don't want to poke a hole and then find out I was wrong. Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425531 Share on other sites More sharing options...
June 13, 201311 yr comment_425570 This is from my 5/75 280z Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425570 Share on other sites More sharing options...
June 14, 201311 yr Author comment_425604 Thanks Jonathan, Thats exactly what I was looking for. I appreciate it! One more question, what holds the top of the taillight surround panels to the body? Is yours rivets or screws? (Runs along the flat area where the hatch closes down) Thanks again for your help, I took this car apart 7 years ago and didn't take enough pictures.Bryan Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425604 Share on other sites More sharing options...
June 14, 201311 yr comment_425613 Thanks Jonathan, Thats exactly what I was looking for. I appreciate it! One more question, what holds the top of the taillight surround panels to the body? Is yours rivets or screws? (Runs along the flat area where the hatch closes down) Thanks again for your help, I took this car apart 7 years ago and didn't take enough pictures.BryanI have a 280Z 1977 whish is probably the same. It uses screws (philips head with a thin metal pressed washer) to hold the top of the taillight panels. Thats the plastic inside panel and the outside surrounds and taillight plate.Chas Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425613 Share on other sites More sharing options...
June 14, 201311 yr comment_425643 I think this is what you are asking for. The are plastic rivets with push pins in the middle. Get them from MSA. Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425643 Share on other sites More sharing options...
June 14, 201311 yr comment_425644 For my 5/75 280z, the plastic tail light panel fastens to the hatch deck using the same plastic interior rivets you find all over the interior.For my 6/72 240z the tail light panel fastens using tiny versions of the plastic interior rivets.Both cars are low mile cars with original paint and are very original so I feel pretty confident that they are as the were when new. Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425644 Share on other sites More sharing options...
June 14, 201311 yr comment_425645 I think this is what you are asking for. The are plastic rivets with push pins in the middle. Get them from MSA.[ATTACH=CONFIG]63983[/ATTACH]This is exactly what my 5/75 280 uses. Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425645 Share on other sites More sharing options...
June 15, 201311 yr comment_425697 I wonder if one of these seatbelts will work in a 240Z. Link to comment https://www.classiczcars.com/forums/topic/46737-1975-280z-owners-seat-belts/#findComment-425697 Share on other sites More sharing options...
