Posted June 28, 201312 yr comment_426566 I have finally fixed the old air conditioning with a new rotary compressor and am getting cold air. There doesn't seem to be any direction on how to set the environmental control levers in the dash for the best use of the ac. Would someone please let me know where the levers need to be set? Obviously the heat needs to be off, but where else are the levers set?Thanks,Charlie Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/ Share on other sites More sharing options...
June 28, 201312 yr comment_426572 When you say "factory Air Conditioning", I think you mean "dealer installed Air Conditioning". I think Factory air was not available until August of 1973.For a dealer installed system, at least on earlier series 1 cars with Frigi-king units, all heater/vent function control levers should be in the left, OFF, position. Your system should have an air conditioning controller mounted either at the bottom edge of dash below the emergency flasher switch for Frigi-King, or on the front, left edge of the center console for another dealer installed manufacturer which I can't remember right now. With this controller you can turn the A/C on or off.The reason, on early Frigi-King cars, that the top OFF-VENT-HEAT slide lever on the heater control panel needs to be in the OFF position is: 1. A mirco-switch is installed at this vent door actuator cable located behind the fan motor on the passenger side under the dash. You can follow this actuator cable up to the right side of the heater plenum behind the heater fan motor/squirrel cage housing to locate where this micro-switch is installed at the pivot point of this vent door cable actuator. 2. If the air conditioning controller is left in the ON position, moving the top heater control lever from VENT to OFF will turn the Acompressor on, and visa versa. I used to just leave my A/C controller in the ON postion, and would turn my A/C on or off by must moving this top heater control slide lever between VENT and OFF to controll the A/C.I welcome any corrections to this analysis, and hope this explanation is helpful.Dan Edited June 28, 201312 yr by AZ-240z Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-426572 Share on other sites More sharing options...
June 28, 201312 yr Author comment_426582 Thanks Dan! That is exactly the info I was looking for. Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-426582 Share on other sites More sharing options...
June 28, 201312 yr comment_426588 Thanks Dan! That is exactly the info I was looking for.You are quite welcome, Charlie. Glad I could be useful.Dan Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-426588 Share on other sites More sharing options...
December 29, 201311 yr comment_438690 I own a 1972 Datsun 240z that has never had an AC system installed.i really need to know where to buy a kit that will fit perfectly in my 1972Datsun 240Z with no components hanging down underneath the passengersglove box? Will i be able to opérate it using the original indash accontrol knobs actually present in the car?Does this kit include all the parts i need such as the lines, thecontrol unit, the harness, the compressor aluminium bracket, the drainhose, the low pressure switch, expansion valve, vacuum tank and vacuumhoses, etc...The main purpose is to be able to use the indash controls as per your case. Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-438690 Share on other sites More sharing options...
December 29, 201311 yr comment_438694 For the A/C unit to hang down in the passenger foot well, I think you need to go with a custom, in-dash HVAC such as Hot Rod Air Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-438694 Share on other sites More sharing options...
December 30, 201311 yr comment_438712 Courtesy Nissan has the complete AC kit for your car for $999.99. Check their web site. It will duct the cold air through your existing dash vents. No added vents under the dash. MSA also sells the kit and I think it's drop shipped from Courtesy.I have that kit in my '71 Z as a replacement for the older AC I had installed in 1972.Dennis Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-438712 Share on other sites More sharing options...
December 30, 201311 yr comment_438736 Courtesy Nissan has the complete AC kit for your car for $999.99. Check their web site. It will duct the cold air through your existing dash vents. No added vents under the dash. MSA also sells the kit and I think it's drop shipped from Courtesy.I have that kit in my '71 Z as a replacement for the older AC I had installed in 1972.DennisHi Dennis,I'm curious if you installed the AC kit yourself. If so, how difficult a procedure was it?I just tried to connect to Courtesy Nissan but could not connect to their web site. MSA lists a kit but doesn't provide many installation details.Cheers,George Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-438736 Share on other sites More sharing options...
December 30, 201311 yr comment_438743 Hi Dennis,I'm curious if you installed the AC kit yourself. If so, how difficult a procedure was it?I just tried to connect to Courtesy Nissan but could not connect to their web site. MSA lists a kit but doesn't provide many installation details.Cheers,GeorgeHi George,My mechanic did the installation for about $600. The cost included removing all of the old AC components from 1972 - York compressor, etc.Here's the link to the Courtesy AC unit:1970-1973 240Z A/C (R134 freon) :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.comInstructions are minimal. I suppose they assume the buyer will either have the skill to figure it out or have it done by a pro. I bought the kit through MSA, but it was shipped from Texas, leading me to believe it came from Courtesy - same price both places.Dennis Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-438743 Share on other sites More sharing options...
December 30, 201311 yr comment_438744 Hi George,My mechanic did the installation for about $600. The cost included removing all of the old AC components from 1972 - York compressor, etc.Here's the link to the Courtesy AC unit:1970-1973 240Z A/C (R134 freon) :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.comInstructions are minimal. I suppose they assume the buyer will either have the skill to figure it out or have it done by a pro. I bought the kit through MSA, but it was shipped from Texas, leading me to believe it came from Courtesy - same price both places.DennisThanks, DennisI just noted that Courtesy suggests 'professional' installation. Also, they are asking $150.00 less than MSA at this time.Won't need it up here for a few days...temps are predicted to go as low as -30F !!Cheers,George Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-438744 Share on other sites More sharing options...
December 30, 201311 yr comment_438760 Won't need it up here for a few days...temps are predicted to go as low as -30F !! Now, if you could just can and compress some of that -30º and save it for use in the summer.......... Dennis Link to comment https://www.classiczcars.com/forums/topic/46861-controls-for-factory-air-conditioning-on-my-72-z/#findComment-438760 Share on other sites More sharing options...
