Posted July 10, 201311 yr comment_427273 got 72 240 and has no keys at all, can you get a complete lock and key set Link to comment https://www.classiczcars.com/forums/topic/46938-new-keys/ Share on other sites More sharing options...
July 10, 201311 yr comment_427279 Yes but not very cheap... Some one may have a used set...Charles Link to comment https://www.classiczcars.com/forums/topic/46938-new-keys/#findComment-427279 Share on other sites More sharing options...
July 10, 201311 yr comment_427285 Full sets show up on eBay now and then. The best approach would be to buy a new ignition switch WITH keys (& steering lock collar) on Ebay and pay a mechanic to install it for you.Next, take a door apart (take the window crank and armrest off, pull the trim off) and pull one of the door locks out. Take it to a locksmith and have them make you keys for it. Should only be $35 or so. If you do this FIRST, you may get lucky and have that same key work in the ignition. You may end up with two different keys, one for doors, and the other for ignition, and that's a good thing because a theif can't slide-hammer a lock out of your door, go and make a key, and have it work in your ignition. Link to comment https://www.classiczcars.com/forums/topic/46938-new-keys/#findComment-427285 Share on other sites More sharing options...
July 10, 201311 yr Author comment_427302 good ideal thank you Link to comment https://www.classiczcars.com/forums/topic/46938-new-keys/#findComment-427302 Share on other sites More sharing options...
July 10, 201311 yr comment_427339 firedan said: good ideal thank you firedan - why buy new locks when you just need keys fitted to your existing locks ? Please just phone a decent locksmith that still does cars in your area. No I won't quote pricing - but one call, half hour's labour , 2 keys later- done. I am a locksmith so it's free advice from a pro ! Link to comment https://www.classiczcars.com/forums/topic/46938-new-keys/#findComment-427339 Share on other sites More sharing options...
July 11, 201311 yr Author comment_427431 got new keys and all is well and the awesome locksmith not even charge me he had key in 5 min thanks all for the help Link to comment https://www.classiczcars.com/forums/topic/46938-new-keys/#findComment-427431 Share on other sites More sharing options...
July 12, 201311 yr comment_427453 I have a NOS lock set on ebay now but unfortunately it's not cheap Lock Set with Ignition and Two Keys Datsun 240Z 260z 280z 280ZX RARE | eBay Lots of other items available also. Matt Link to comment https://www.classiczcars.com/forums/topic/46938-new-keys/#findComment-427453 Share on other sites More sharing options...
July 12, 201311 yr comment_427454 See, you were told this was a neat place to get help...... Good job Link to comment https://www.classiczcars.com/forums/topic/46938-new-keys/#findComment-427454 Share on other sites More sharing options...
