Posted July 19, 201311 yr comment_428037 Ey guys.Can someone write down what the difference between the early 70 Z eu and us spec editions r? Link to comment https://www.classiczcars.com/forums/topic/47016-1970-z-eu-and-us-spec-differences/ Share on other sites More sharing options...
July 19, 201311 yr comment_428039 This is a start: https://www.google.com/search?num=100&newwindow=1&q=euro+spec+site%3Aclassiczcars.com&oq=euro+spec+site%3Aclassiczcars.com&gs_l=serp.3...58533.63602.0.65119.9.9.0.0.0.1.142.748.7j2.9.0....0.0..1c.1.20.serp.D8xAEXTiZa4https://www.google.com/search?num=100&newwindow=1&q=alan+hs30-h+site%3Aclassiczcars.com&oq=alan+hs30-h+site%3Aclassiczcars.com&gs_l=serp.12...24245.31075.0.33843.11.9.2.0.0.0.71.558.9.9.0....0.0..1c.1.20.serp.HkRI1NB17rw Link to comment https://www.classiczcars.com/forums/topic/47016-1970-z-eu-and-us-spec-differences/#findComment-428039 Share on other sites More sharing options...
July 20, 201311 yr Author comment_428119 Tnx for those links Also, saw that the EU spec has specific spring colors. Does the US spec too? If u can tell me, which? I'm at the phone only in the next few days Link to comment https://www.classiczcars.com/forums/topic/47016-1970-z-eu-and-us-spec-differences/#findComment-428119 Share on other sites More sharing options...
July 20, 201311 yr comment_428127 You can get details on US versions by looking in Factory Service Manuals front and rear suspension sections here:XenonS30Some info here: http://atlanticz.ca/zclub/techtips/springs/index.html Link to comment https://www.classiczcars.com/forums/topic/47016-1970-z-eu-and-us-spec-differences/#findComment-428127 Share on other sites More sharing options...
July 20, 201311 yr comment_428141 I know that the coil plate for the spring is welded at a different height on the strut towers. I have seen a thread (cant find it now) with two coil plates on the rear strut tower. The poster was wondering why the other plate was much lower and why it was there in the first place. That was because someone found a Euro strut and fitted it to a US spec 240Z. Probably because he damaged the lower part of the strut and could reuse the coil plate on the euro strut.The euro spec also uses the roadster 5speed.Australia also used mostly the euro spec which might help.Remember euro spec can change per country in Europe. Mostly turn signals / parking lights and such.Chas Link to comment https://www.classiczcars.com/forums/topic/47016-1970-z-eu-and-us-spec-differences/#findComment-428141 Share on other sites More sharing options...
July 20, 201311 yr Author comment_428144 And i thought only the lights were different... damn, i got lots of work to do before it gets released for the public tnx for the info guys! Link to comment https://www.classiczcars.com/forums/topic/47016-1970-z-eu-and-us-spec-differences/#findComment-428144 Share on other sites More sharing options...
July 23, 201311 yr comment_428312 Yep, Im trying to make a timeline for the engines in the US market, but its turning out to be harder than I expected. There is lots of info for the US models, but its not all that reliable.I would imagine the Europeanen market would be more challenging. You just have to keep slowly working at it.Goodluck with it and if I find anything Ill let you know.Chas Link to comment https://www.classiczcars.com/forums/topic/47016-1970-z-eu-and-us-spec-differences/#findComment-428312 Share on other sites More sharing options...
