Gas filler hose leak fix?
derbyD
My gas filler hose that connects from the gas tank to where you put the pump nozzle in, has a little hole in the rubber hose just above the hose clamp that connects the hose to the gas tank. It is a very little hole but enough for the fuel to leak out during filling or when the fuel is that high in the tank. My question is, will JB weld, Ultra Blue or Permatex "Form A Gasket Sealant" wrapped with foil tape stop the leak? Does anyone have an idea that could. I'm low on cash so buying a new hose is kind of out of the question. Thank you for reading.
Your profile identifies the car as a '69 so you are dealing with a 43 year-old part that may be compromised in other areas. Do you really want to run the risk of driving a car with fuel leaks around the tank and the potential for dangerous fumes getting inside the car? I know it's a PITA to change it out but what is your life worth?
