May 23, 201410 yr comment_448386 Just saw you picture from a week ago, here is a picture of my stock 76 280 in that area. Hope this helps. Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448386 Share on other sites More sharing options...
May 28, 201410 yr Author comment_448666 Took advantage of the 3 day weekend and made some more progress on the Z. Got to clutch issue straighten out. The aftermarket rod on the Clutch MC I installed was too short. I extended it about an inch and that magically fixed all my clutch issues. Got to take the Z out for some break in miles. So far so good, the car rides very nice and cruises great at 70. The engine is running lean so I'm going to adjust the AFM to see if I can richen it up. My next major project is the headlights. At first only the right on was working. I unplugged the left one, cleaned the ground, re installed it and now neither work! Except the right high beam. I'm getting power at the fuse, so it seems like I have an electrical gremlin somewhere. There's a car show Friday night I'd like to take it to, but only if I can get the headlights working. Right now I'm daylight restricted. Here's a video of me pulling it out of the garage for the first time and a few glamour shots I took while breaking it in. Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448666 Share on other sites More sharing options...
May 28, 201410 yr comment_448667 CG240Z said: The engine is running lean so I'm going to adjust the AFM to see if I can richen it up. Many of us have had better luck with a potentiometer on the coolant temperature circuit to add resistance, to fix a lean problem. Messing with the AFM spring changes the slope of the enrichment curve, richer at the bottom not so much at the top, adding potentiometer resistance just moves the whole thing up. Richer everywhere. Plus, if you mount it in the cabin, you can tune on the fly. Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448667 Share on other sites More sharing options...
May 28, 201410 yr Author comment_448670 Zed Head said: Many of us have had better luck with a potentiometer on the coolant temperature circuit to add resistance, to fix a lean problem. Messing with the AFM spring changes the slope of the enrichment curve, richer at the bottom not so much at the top, adding potentiometer resistance just moves the whole thing up. Richer everywhere. Plus, if you mount it in the cabin, you can tune on the fly.Very interesting. I've seen others reference potentiometers, but didn't exactly know what they were used for. I'm looking at the Atlantic Z site now and reading up on it. I ordered a 1k adjustable potentiometer as he has on the site. It will be here tomorrow. As far as wiring it, I'm a little confused. I get that it wires into the temp sensor, but that's about all I'm understanding. Could you further clarify how to wire it inline with the temp sensor? Thanks! Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448670 Share on other sites More sharing options...
May 28, 201410 yr comment_448702 The atlanticz page shows the coolant sensor with both bullet ends disconnected, for demonstration, so is a little confusing. But you only need to break open one connection, and insert the potentiometer in-line. It can be before or after the sensor. All you're doing is adding resistance to the wire that starts at Pin 13 on the ECU and goes to ground. The ECU will think that the engine is colder than it is and add fuel. The sensor's resistance increases as temperature drops. It won't take much, I hope that you got a taper style potentiometer, they have a finer touch on the ends of their adjustment. I ran a few feet of wire from the connection on the engine harness and mounted the pot under the driver's side dash. In the engine bay is fine if you don't plan to mess with it much. Make sure it doesn't get too hot, it's probably not designed for engine bay temperatures. I added a picture from the Fuel Injection Book, illustrating the circuit and the bullet connections. Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448702 Share on other sites More sharing options...
May 28, 201410 yr comment_448703 I made mine with enough cable to tweak it in the cabin until it seemed right. After that I mounted it along the fuel rail. This pod is a 5k ohm unit I had a 20k ohm, but it was a little course and harder to fine tune. Chas Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448703 Share on other sites More sharing options...
May 28, 201410 yr Author comment_448710 How are you guys determining what size potentiometer to use? Is it a trial and error thing? It seems the bigger you go, the harder it would be to fine tune. I got a 1k, I'm going to install it today and max it out. See if I notice a difference from there. Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448710 Share on other sites More sharing options...
May 28, 201410 yr comment_448711 Start at zero and work up. The pot is actually a good theft-prevention device. Just crank it up and you'll flood the engine. I have a 5K from Radio Shack and I barely use 5 degrees of knob rotation. Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448711 Share on other sites More sharing options...
May 28, 201410 yr comment_448728 CG240Z said: Took advantage of the 3 day weekend and made some more progress on the Z. Got to clutch issue straighten out. The aftermarket rod on the Clutch MC I installed was too short. I extended it about an inch and that magically fixed all my clutch issues. Got to take the Z out for some break in miles. So far so good, the car rides very nice and cruises great at 70. The engine is running lean so I'm going to adjust the AFM to see if I can richen it up. My next major project is the headlights. At first only the right on was working. I unplugged the left one, cleaned the ground, re installed it and now neither work! Except the right high beam. I'm getting power at the fuse, so it seems like I have an electrical gremlin somewhere. There's a car show Friday night I'd like to take it to, but only if I can get the headlights working. Right now I'm daylight restricted. Here's a video of me pulling it out of the garage for the first time and a few glamour shots I took while breaking it in. [ATTACH=CONFIG]71747[/ATTACH] [ATTACH=CONFIG]71748[/ATTACH] [ATTACH=CONFIG]71749[/ATTACH] [ATTACH=CONFIG]71750[/ATTACH] Beautiful Car! I recognized it from instagram . My 280 arrives on friday. Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448728 Share on other sites More sharing options...
May 29, 201410 yr comment_448780 CG240Z said: How are you guys determining what size potentiometer to use? Is it a trial and error thing? It seems the bigger you go, the harder it would be to fine tune. I got a 1k, I'm going to install it today and max it out. See if I notice a difference from there.I used a 2k ohm pod from Alpha p/n; B2K. Its adjusted to about 1000ohms.RV16AF-10-15R1-B2K Alpha (Taiwan) | MouserChas Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448780 Share on other sites More sharing options...
May 29, 201410 yr Author comment_448785 I installed a 1k yesterday and have it turned up about 3/4. Haven't pulled the plugs yet but there's a huge improvement. The car isn't bogging down any, the overall smoothness of the engine is much better. Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448785 Share on other sites More sharing options...
May 29, 201410 yr comment_448789 Hey guys,I'm about to start profiling weber's a/f ratio's vs configuration changes. I'll try to do the same for EFI systems this summer and measure what the A/F ratio changes for teeth changes of AFM and resistor changes at the temp sensor as well as idle and WOT enrichment. May even pull out the scope and measure injector pulse width changes. Link to comment https://www.classiczcars.com/forums/topic/47115-280z-full-restore-in-5-months-hopefully/?&page=15#findComment-448789 Share on other sites More sharing options...
