I just checked mine on my '70 and three of them are M4 x 0.7mm with a Phillips head and strangely one is a No. 8-32UNC with a slotted head.
Mike
Just an update, when I reinstalled the screws the M4 x 0.7mm did feel like a better fit.
Edited by CanTechZ
This is probably not helping you now, but could be handy later when trying to identify bolt sizes in your Z.
I think Datsun almost always used what is known now as the ISO standard for screws and bolts.
The ISO thread standard has been around more or less since 1966 and is made up several documents.
These are the most used:
ISO 68-1 Profile (Thread cross section)
ISO 261 General plan (Diameter and pitch combinations)
ISO 965-1 General Tollerances
ANSI and SAE worked with ISO in the early seventies and ASME jointed in later. The more you read standards the more confusing it gets.
ASME has a good document you can use to find threads and I think it would be exceptional if you found a thread in a Datsun that is not mentioned. With exception of left hand threads which is another standard.
http://www.cmpubolt.com/docs/B1.13M-2005.pdf. (see document page 9 to11)
Chas
