Posted August 4, 201311 yr comment_429089 hello, can anyone confirm that the early series 240s (7/70) have a metal squirrel cage fan under the passenger dash - or should it be a plastic fan? thanks Ken Link to comment https://www.classiczcars.com/forums/topic/47131-fan/ Share on other sites More sharing options...
August 5, 201311 yr comment_429137 Hello Ken,To be correct, the squirrel cage fan should be metal for series 1 cars. No sure when the use of plastic started, but I seemto remember that the pastic would put out a little more volume, but was interchangeable with the metal fan squirrel cage fans.Dan Link to comment https://www.classiczcars.com/forums/topic/47131-fan/#findComment-429137 Share on other sites More sharing options...
August 5, 201311 yr Author comment_429138 thanks! i've to the metal one in the car - its a beast, must weigh 5 lbs! it was making noise on the high setting, so was wondering if this one could be a solve. will leave the metal beast in there.... Link to comment https://www.classiczcars.com/forums/topic/47131-fan/#findComment-429138 Share on other sites More sharing options...
