Recently Browsing 0
I know there's lots of threads about this...and I think I've read them all. I installed my triples last year and decided to keep the stock mechanical fuel pump. It puts out quite adequate volume and pressure for the triples. I have a pressure gauge before the carbs and regulator on the tank return line which keeps the pressure at 3-4 psi. The car runs great even under heavy acceleration...no fuel starvation.
My question: why does it take so much cranking to get fuel to the carbs for the engine to fire when cold and the car has sat for a while? The pump is supposed to have a check valve to prevent draining of fuel back into the tank.....correct? It seems I'm pumping new fuel from way back at the tank. I do have the stock electric fuel pump at the tank, but that doesn't kick in till the engine cranks up to a certain rpm. When warm the engine cranks quickly. I had the same problem with stock SU's....lots of cranking when cold. I know most have gone the electric pump route with inertia switches and stuff. I know the carb bowls will eventually evaporate, but the mechanical pump volume can easily fill those. (I know the fuel evaporates as my garage stinks for a day after running the car...that's a question for another thread: Stinky Webers)
What simple, dumb thing am I over looking?
https://www.classiczcars.com/forums/topic/47157-fuel-pump-for-triple-webers/Share on other sites
