Email logins are now active ×
Fan clutch or other issues?
Pomorza
Guys
This weekend was supposed to be wonderful. A group of friends and myself were going to meet up at a lake and have a wonderful camping trip. Well as expected there were issues from the start. On the way to said lake I forgot some things at home and decided to head back. As I drive into my neighborhood I notice my temp gauge is not where its normally supposed to be, to be exact its a notch or so past the midway point, it normally runs at like 1/3. Freakout I pull into the spot and open the pressure relief on the radiator cap - yes I know you're not supposed to do it I wasn't in the right state of mind - steam comes pouring out for a good five minutes. Stumped I attach my laptop to my computer (I run aftermarket EFI) and see what the temp read;, 208 is what it see. I let the car cool off for a while, refill the radiator and off I go keeping a close eye on the temp.
While driving in the city it hovered around 195, way above what I'm used to but nothing that I would worry about. As I get stuck in traffic and move inches per hour the temp begins to rise, when it hits 210 I open the heater valve (don't actually turn the heat on though, no vents) and watch as the temp drops to 198 and stays there for a while until I get moving again. I drive on to the freeway and continue to montior the temp, which slowy drops to the mid 180's at 75ish mph. I pull the pull into a gas station to fill up and make sure the radiator fluid was in good shape. When I reenter the car the temp gauge is roughly in the middle and the temp on my computer reads 219, but drops rapdily once I start the car. From then on it gets interesting. The road to the lake is rather long and windy through southern Arizona. Outside temp sits at around 85 or so. I'm driving the usual 50 or so and the temp, as if nothing had happened before, goes back to where it had run before. The rest of the trip to the lake and back this evening the temp never exceeded 175, dipping in to the low 160's at times.
So here's my question. From my knowledge of cars - which isn't amazing but I know a bit - it sound to me as if my fan clutch maybe giving out. I'm not an expert and have reviewed a few posts here about cooling but if I had a pressure issue wouldn't the temp always be high or at least elevated and not fluctuate like it did? I run a 160 degree thermostat, the radiator is about three years old, the water pump is 2 years old. All the hoses are new, there are no leaks and since I added fluid into the overflow it has remained constant. There is no white smoke (or sweet smells) - had the friends drive behind me, the oil is oil (needs a change but is oil) and the coolant is nice and green. Any ideas on what this could be?
Sorry for the book
Thanks again
Jan
Edited by Pomorza
Thank lads
I will confirm the diagnosis later this week. When the car is cold there is a bit of resistance in the fan, haven't tested it at operating temp just yet. I do have a question though, should I replace the stock clutch with a new one (which is roughly $50) or spend slightly more and get a dual speed electric fan? The one(s) I've looked at have a 1500 cfm rating on high, I don't know how that compares with a stock Z fan so suggestions are welcome.
Thanks
Jan
I've got a dual electric fan out of a late model junkyard altima that I got for like $18 at the local self service yard. Both fans on the low setting will overcool my car on the hottest of days. I don't even have the high speed windings wired up.
If originality isn't a concern and you don't mind wiring up electric fans, it's the way to go in my opinion.
Thats too big of a fluctuation in temp. 50 degrees to be exact. Too much. You are running a 160 thermostat and you still get up to 210 and it sounds as if it would keep climbing if you don't open the heater core. Are you sucking air anywhere? Have the system pressure tested. I had an over heating problem once due to a leak. You can also check the fan clutch by running the car up to temp and with a rag balled up in your hand VERY CAREFULLY try to stop it from spinning. Apply just a little pressure on the fan and you will know. If it slows down it's no good. If it fights you and will not slow down it's good and then at that point I would look for a leak, (air) in the system. Just be sure before you go buying things that you may not have to buy you have verified the cooling system is working properly.
Edited by rcb280z
Update:
Ran both tests today. Took the car from my house up to my brothers (~3 miles way) to get the car to operating temperature. Arrived at my brother's place and the Z sat at 173. Let it idle for about 10 minutes and checked temperature again was now at 177. Step one, check the fan. Took a new paper, rolled it into a tube and attempted to stop fan. Fan nearly took newspaper AND my arm with it, so that would be a pass. Turned car off. Step 2. Tested pressure, hooked up pressure tester, took it up to 13 psi (per rating of cap) and check for leaks. Pressure kept steady at ~13 for about 15 minutes while I checked around. Step 3. Checked flow of radiator. Took off pressure tester and started the Z. Temp after sitting was 194. Two things I noticed. 1. The flow was amazing, the coolant was moving so fast from one side of the radiator to the other that it nearly came out of the damn radiator. Secondly the fan was ON, as it sounded like I had a messerschmitt sitting under my hood. Step 4. Drove car back home. After placing everything back to where it needed to be I closed the hood and drove back home. Even in the 100+ degree heat of Tucson the temp never exceeded 175. The fan was also on most of the drive home - as I could hear it.
So, it seems that everything checks out in my cooling systems. I have the suspicion, that my fan wasn't on the day it over heated as it didn't seem that loud for what I remember. I don't know exactly how these fail - if its a gradual loss of function or if it can fail and not fail. Would like to hear your opinions.
Thanks
Jan
Update:
So, it seems that everything checks out in my cooling systems. I have the suspicion, that my fan wasn't on the day it over heated as it didn't seem that loud for what I remember. I don't know exactly how these fail - if its a gradual loss of function or if it can fail and not fail. Would like to hear your opinions. Also the coolant is coolant, nice and GREEN. The oil is still oil, dirty and in need of a change but its oil.
Thanks
Jan
Sounds like a Messerschmidt eh? I have limited experience with fan clutch failure, but mine failed in the "on" position and that'd be an apt description of the ruckus coming from under my hood. I'm just making a guess here, but I wouldn't rule out the possibility failing fan clutch going from "slipping too much" to "seized in place" and giving you the problems you described. Try and move the fan by hand with the engine cold and stopped, if it is seized in place like it's bolted to the water pump then it still needs replacing.
Alternatively if you had the coolant system drained recently, a bubble in the coolant can give you a world of overheating that suddenly goes away when the bubble burps out.
  • Who's Online   2 Members, 0 Anonymous, 1,111 Guests (See full list)
