Posted August 13, 201311 yr comment_429652 Higuys,Does anyone know the part #, or a source, (not a junkyard) for a 1994 Maxima door Chime/lights-on reminder unit? It's about the only "ding-dong" sound that you can get for under $1000. I'd like to use it as a lights-on reminder. Does anyone have any favourite chime sound units that you can actually buy?thxZ Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/ Share on other sites More sharing options...
August 13, 201311 yr comment_429653 I found the first generation Integra (85-89) headlight chime to be quite polite. Not the key in the lock warning, but the headlight chime.The key left in lock is your ubiquitous "beep-beep-beep-beep", but the headlights are this very polite "bing-bong" thing. Sounded like they even used mechanical bells struck by a clapper of some sort instead of it being electrically generated.Don't know if you can buy the module aftermarket, but if you're junkyard hopping, it might give you another alternative to try. Might also be on later modules as well, but I don't know for sure. Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-429653 Share on other sites More sharing options...
August 13, 201311 yr Author comment_429658 I just like the ding-dong of the older Maxima. It's not so 'mechanical-sounding.' Any light ding-dong chime will do, but be aware that many manufacturers are using the vehicle's stereo system for the chimes and buzzers, which I think is dumb. :disappoin Edited August 13, 201311 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-429658 Share on other sites More sharing options...
August 13, 201311 yr Author comment_429666 The local dealer tells me it's 25065-32R00 but he wanted the VIN for the vehicle for an exact part. $60 (!!) for that little box?? I think maybe you get a whole bunch of stuff. Edited August 13, 201311 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-429666 Share on other sites More sharing options...
August 14, 201311 yr comment_429700 Any S130 (ZX) will also have the Ding-Dong chime you speak of. For me, I kinda like the buzzer of the old Z - Depending on the weather, mine either is buzzing as it should - or it sounds like it is real drunk, almost like a sad cartoon buzzer. That is one of the many charms of the Z. Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-429700 Share on other sites More sharing options...
August 14, 201311 yr comment_429729 For me, I kinda like the buzzer of the old Z - Depending on the weather, mine either is buzzing as it should - or it sounds like it is real drunk, almost like a sad cartoon buzzer. That is one of the many charms of the Z.Mine does that too, and I can't help but laugh at it sometimes. Bzzzz...Bzzzz...bbghghzzz... Sometimes it sounds like it randomly gets tossed into a bucket of water and it's drowning. Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-429729 Share on other sites More sharing options...
August 15, 201311 yr Author comment_429787 Some research by my friend Loy tells me that the ding-dong dingers were used even on the '94 Maximas, but I suspect that the more modern units are probably more than just a little box with a 2-pin connector. Is that correct? For example, the beeper/chime on my '97 Escort has 4 connectors with about 8 wires on each (or about 30 connections.) Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-429787 Share on other sites More sharing options...
November 29, 201311 yr Author comment_437107 I was able to get one from eBay, and it was either a dud, or you just can't hook it up to a car battery. Without a wiring diagram for the vehicle it was from, I can't do anything more to get it to work.The odd thing about this unit is that it is pretty much a mechanical chime like your average house doorbell. there is a Durite Buzzer, 12 volt Cd1 - 0-562-00 that is an electronic unit, but I can't locate a sound file or video for it to confirm the kind of sound it actually has. Maybe someone can share their knowledge of the Durite chime? Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-437107 Share on other sites More sharing options...
November 30, 201311 yr comment_437110 Andrew, I agree about the charm of the Z's buzzer. It sounds very much like a hangover from the Cold War, along with the big, hunkin' "seat belt" light that flashes with it. I kept mine intact for a very long time, smiling whenever it would buzz. But eventually I got tired of listening to it. I disconnected it, just as I've done with almost every other door chime I've ever had. However, it's still there under the dash, just waiting to be plugged back in for a trip down memory lane. Maybe I should put a switch under the dash to turn it off and on, depending on my mood. Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-437110 Share on other sites More sharing options...
December 3, 201311 yr comment_437300 Haha, "ding-dong-dingers", how funny is that I had buzzer in my Z, the most pathetic sound i've ever heard. I decieded to put it down. Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-437300 Share on other sites More sharing options...
December 3, 201311 yr Author comment_437346 It might be pathetic, but it sure gets your attention! That's probably why... Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-437346 Share on other sites More sharing options...
December 4, 201311 yr comment_437389 I elected to go a different route. The coil will be powered off of the ignition switch. I'm going to wire this buzzer through the normally closed contact and power the buzzer off of the running lights circuit. Edited December 4, 201311 yr by SteveJ Link to comment https://www.classiczcars.com/forums/topic/47188-source-for-a-1994-maxima-chime/#findComment-437389 Share on other sites More sharing options...
