Email logins are now active ×
Coolant leak-how to proceed?
madkaw
nah, Steve. Really not that bad when going new.
PO had stripped a threaded hole and put an over-sized stud in place of it. Replaced it cause it looked ugly as hell.
About half hour tops. (not including the 48 hours of multiple doses of PBlaster).
Edited by mlc240z
Replacing the housing is not te hard work as I said earlier - it's the removing the complete induction system to get to it.
I did pressure test the coolant system and best I can tell the leak is at the housing mounting point. Just as long is its not the HG!
