The Spruell Motorsport shipment just arrived with the stronger Weber 40 DCOE Throttle Springs. These springs are used to firmly close the throttle plates shut. This ensures consistent performance as explored and discovered in this thread:
http://www.classiczcars.com/forums/carburetors-s30/48969-weber-internal-spring.html
For reference, here are the Weber part numbers:
47605.012 Weaker
47605.027 Standard
47605.009 Stronger
I decided to measure the spring constants of the springs I had on hand for reference:
?????????? (is from Pierce Manifold sold as 47605.009 BEWARE)
New
713.2 N-m
526 Ft-Lbs
47605.027
Used
1,634.4 N-m
1,206 Ft-Lbs
47605.027
New
1,669.2 N-m
1,231 Ft-Lbs
47605.009
New
2,203.7 N-m
1,625 Ft-Lbs
  • I am not sure of the age of the used standard spring but it has not aged much.
  • Clearly Pierce sent the incorrect spring.
  • The stronger .009's are ~ 33% stronger
Edited by Blue
https://www.classiczcars.com/forums/topic/47248-dcoe-throttle-spring-testing/
  • 1 year later...
Dr.240z and I swapped in the new stronger springs in his triple 40DCOE set up.
We were able to swap them with the carbs on the car (just removed the top carb plate). A small screw driver and long needle nose pliers were the only tools needed.
It certainly closed the 3 throttle plates to the same location as repeated idle measurements were ~ 935 +/- 5 rpms.
No increase in pedal pressure was noted.
It did the trick!
  • 2 years later...
