August 27, 201311 yr comment_430572 zKars said: "Give a man a fish, and he eats for a day. Give a man a fishing pole and his wife will never see him again on weekends...."Would that work in the opposite way? Girlfriends birthday is soon. Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430572 Share on other sites More sharing options...
August 27, 201311 yr comment_430576 Yes, if you give her a fish, she might indeed go away. For more than a weekend. Oh, sorry, you mean the OTHER opposite way, if YOU gave Her a fishing pole, then.... uh,... no, sorry, same result.... Edited August 27, 201311 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430576 Share on other sites More sharing options...
August 28, 201311 yr comment_430588 No, I think he was suggesting that the fish give his girlfriend a pole and then.... Uh... No, that can't be right either. Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430588 Share on other sites More sharing options...
August 28, 201311 yr comment_430604 I think he's saying "give a man a girlfriend for a weekend and his wife will never see him again". No wait...what? Edited August 28, 201311 yr by tlorber Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430604 Share on other sites More sharing options...
August 28, 201311 yr comment_430616 If it has been sitting for over 10 years don't expect it to be drivable by putting new fluids in it. Sitting for a decade is pretty hard on anything in a car that relies on rubber bits.... and there are lots of them. Pretty much everything in the brake system & the fuel system will have to be systematically gone through to make it a driver. My car sat for around a decade before I got it and here is a probably incomplete list of everything it needed to actually be a quasi-reliable car: New front brake calipers New rear brake cylinders All brake flex lines Brake master cylinder Brake vacuum booster Clutch master cylinder Clutch slave cylinder Clutch flex line New gas tank (happened to be cheaper than boiling out the original tank) Replaced gummed up carburetors (I'd expect your fuel injectors to be rather unhappy as well) Fuel filter (Late 240Zs like mine have have two!) Fuel pump. New radiator (original had a hole, not really a common problem) New radiator fan (original fan clutch seized solid on the first longish trip I took on a hot day) New shocks all around, 25 year old units wouldn't clear a speed bump past walking speed. Big ole pile of suspension bushings (honestly optional, but I wouldn't wanna drive a car on 40 year old bushings) including the differential mounts (not optional, they were torn and going to start damaging things) New tires, the old ones turned into plastic time bombs. Various electrical things needed refreshing, including and not limited to the turn signal switch and the headlight/wiper switch stalk and a new battery. Also my car needed a clutch, but sitting PROBABLY wasn't the cause of that. On top of this, this is all on my analog carbureted car, so there are more things in the fuel injection system that might need looking into, but I honestly don't know. Look to the 280Z guys for that, it's not my area of expertise! Anyways, if I look at it strictly as a business prospect, I might have made my car worth more than the cost of the parts I put into it so I technically would come out financially on top if I sold it because labor was the low low price of busting my own knuckles and swearing a lot..... but then I'd be out a Z that I've busted my knuckles on and swore at a lot which I would find fully unacceptable My heavily biased suggestion is if you're going to sell it: don't touch a thing and sell it cheap to somebody who is gonna restore it. :tapemouth Edited August 28, 201311 yr by Captain_Zeros Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430616 Share on other sites More sharing options...
August 28, 201311 yr comment_430625 Give a girl a fish, and she'll cook a nice dinner. Give a girl a good fishing pole, and she'll have no more use for that lying, cheating, SOB boyfriend/husband of hers. Oh, FAIW, a lot of the auto parts stores will look up fluid capacities for you (e.g. AutoZone). I'm amazed they have fluid capacities for vehicles as old as my Z, but they do -- and also much older and more obscure. Edited August 28, 201311 yr by FastWoman Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430625 Share on other sites More sharing options...
August 28, 201311 yr comment_430628 Yeah, they'll have "information" about all kinds of stuff for all kinds of cars, but getting parts is a different story. It seems that auto parts stores don't carry parts for cars using distributors or the "old" coil ignitions. Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430628 Share on other sites More sharing options...
August 28, 201311 yr comment_430629 For zeenubee, I'd suggest you get an owner's manual, either in hard-copy form or a digital copy here Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430629 Share on other sites More sharing options...
August 28, 201311 yr comment_430639 FastWoman said: Give a girl a good fishing pole, and she'll have no more use for that lying, cheating, SOB boyfriend/husband of hers. Exactly! Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430639 Share on other sites More sharing options...
August 28, 201311 yr comment_430641 FastWoman said: Give a girl a fish, and she'll cook a nice dinner. Give a girl a good fishing pole, and she'll have no more use for that lying, cheating, SOB boyfriend/husband of hers. hey Fastwoman, You forgot "good for nothing" At least I still mow the lawn and take out the garbageLOL Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430641 Share on other sites More sharing options...
August 28, 201311 yr comment_430649 I know it adds no technical value to the thread, but there sure have been some very creative and entertaining additions to the fish/wife/girlfriend/pole conundrum discussion. Thanks for the chuckles!! :laugh: Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430649 Share on other sites More sharing options...
August 28, 201311 yr Author comment_430661 Thanks!....the guy I bought this thing from said he had redone all of the bushings (front?) just before I bought it...the tires and wheels are really sharp (Panasport Racing/BFG euro T/A)....they haven't been in the daylight so "look" ok....he switched it to a five speed and I,m not sure but believe he put new header on it...it has a metal foil blanket on it...am planning on draining the gas tank and blowing the lines, new fuel filter etc....all brakes will be gone through...not sure how deep I want to go...just have to see if I'm gonna fall in love or if we are just dating.....and where did all this "fish" stuff come from?I did download the manual and I have all the fluid info and more... Link to comment https://www.classiczcars.com/forums/topic/47273-fluid-specs-and-capacities-for-78-280z/?&page=2#findComment-430661 Share on other sites More sharing options...
