Posted August 28, 201311 yr comment_430638 Guys I've got a 78 280z that is in need of an ignition switch. I was wondering if you guys know if the ignitions are swappable between the 240's through the 280's? Basically is it possible to take a whole assembly from a 240 or 260 and swap it into a 280?Thanks! Link to comment https://www.classiczcars.com/forums/topic/47290-ignition-swapping/ Share on other sites More sharing options...
August 28, 201311 yr comment_430648 I don't know if the whole assy's swap, but I do believe there was a design change to the electrical switch part of the assy that resulted in two non-interchangeable versions of the electrical switch.Are you trying to fix an electrical issue, or a mechanical issue? (Or both?) Link to comment https://www.classiczcars.com/forums/topic/47290-ignition-swapping/#findComment-430648 Share on other sites More sharing options...
