Posted August 29, 201311 yr comment_430701 Hello 240z community,So I'm thinking that I need to replace my clutch on my approx. 90K mile, '73 S30 Z with stock 4-speed transmission, but I would like to inquire about the problem on the forum first.The problem with the clutch is that:1. With clutch pedal fully depressed, there is a bit of a problem engaging gears, especially 1st gear at rest.2. Releasing the clutch pedal, clutch engages early in low pedal position, then as power is applied, clutch begins to slip.3. Releasing clutch pedal further as it moves to a higher position, clutch re-engages fully.Question:Do I need a new clutch kit installed to remedy this problem or is it simply a matter of adjustment? If it is adjustment, where should I start?Thanks much in advance,gtom Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/ Share on other sites More sharing options...
August 29, 201311 yr comment_430703 It sounds like you have a problem with hydraulics. Check the fluid level in the clutch master. If it is low you have leak so look for signs of fluid leaking at the slave cylinder and at the master (look in the cabin under the dash forward and above the pedals). The most likely problem is a worn out master cylinder. Replacing the master and slave as a set is common practice but not essential. Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430703 Share on other sites More sharing options...
August 29, 201311 yr comment_430707 gtom said: 1. With clutch pedal fully depressed, there is a bit of a problem engaging gears, especially 1st gear at rest. What about reverse? It should be the worst if the clutch is not dis-engaging completely.2. Releasing the clutch pedal, clutch engages early in low pedal position, then as power is applied, clutch begins to slip. This part doesn't really make sense. It grabs, then slips? Maybe the slave or master cylinder piston is sticking so the fork travel isn't following pedal travel.3. Releasing clutch pedal further as it moves to a higher position, clutch re-engages fully. Does it slip under hard acceleration?Some questions above for clarity and possibilities. beerman is right. If the clutch doesn't slip when it's not supposed to then the problem probably lies in the hydraulics.Edit, after Zkars's post - I've seen it mentioned that bleeding the clutch hydraulics often fixes clutch problems. Might be the quickest, easiest thing to do. Edited August 29, 201311 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430707 Share on other sites More sharing options...
August 29, 201311 yr comment_430711 If you cannot get the clutch to slip with the clutch fully out (foot off) under any driving condition, then your clutch friction surfaces are not the problem. Checking fluid levels and for leaks is definitely step one.I would begin by lengthing the clevis rod under the dash a couple of turns to raise the friction point and see if clutch-applied shifting goes with grinding and friction point become better (higher). If this works for short while then gets worse, time for a new master. Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430711 Share on other sites More sharing options...
August 29, 201311 yr Author comment_430712 Thanks for the replies. The clutch doesn't slip after the pedal is released completely. I'll check the hydraulics, adjust and report back. Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430712 Share on other sites More sharing options...
August 29, 201311 yr Author comment_430720 Ok, I did my inspections and found: 1. Clutch fluid reservoir is low. 2. Evidence of fluid leakage at master cylinder in cabin. (see photo) 3. Evidence of fluid leakage at slave cylinder when rubber boot was pulled back. (see photo) 4. Rubber sleeve at flexible line at slave cylinder decayed/broken. (see photo) Question: Given that I have not bled the system (I recently purchased the car), do the findings above require that the clutch master and slave cylinder be replaced along with the flexible line at the slave? Thanks again in advance. Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430720 Share on other sites More sharing options...
August 29, 201311 yr comment_430723 If the master is leaking, it should be swapped. I tend to follow the line of reason that you may as well do both at the same time and avoid having an issue pop up later. The line will obviously need to be replaced, as well.These parts are fairly cheap, may as well take care of all of it at once. Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430723 Share on other sites More sharing options...
August 29, 201311 yr comment_430724 If you've got evidence of leakage, I'd replace 'em! You sound on the right track with both cylinders and the flex line. That flex line looks pretty end of lifespan to me.All those parts are available pretty inexpensively at RockAuto.As far as clutch friction parts, it's not surprisingly at all if it slips with the pedal partially depressed, clutches are designed to slip when you put the pedal down, what you would need to worry about is if it slips under load when you're not touching the clutch, which you shouldn't be touching the clutch unless you're changing gears (I don't wanna accuse anybody of anything, but just make sure we're at square one in case we need to be! Riding the clutch has worn out many a clutch unnecessarily.) Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430724 Share on other sites More sharing options...
August 29, 201311 yr Author comment_430728 OK, sounds good. I'll go ahead and order the parts and replace and hopefully that will solve the problem. I think I'm now on the right track though since my clutch pedal isn't all that firm and the clutch doesn't slip under load. We shall see...Thanks again for the help! Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430728 Share on other sites More sharing options...
August 30, 201311 yr comment_430753 Bad master for sure. The boot on the slave looks shiny, indicating a leak there as well. Unless you have an urgent need for the car don't waste time filling or bleeding before replacing the bad parts. Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430753 Share on other sites More sharing options...
August 30, 201311 yr comment_430768 Bench bleed the new master, install new slave, hook up the line and you should be able to gravity bleed the slave.While replacing the interior pin on master rod, look for rounding out of the hole in the pedal where the clevis pin goes thru. Can add some slop when you need to adjust. Might have to add a bushing to tighten it up.Pretty straight-forward install, couple of fun hours and you'll be well rewarded. Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-430768 Share on other sites More sharing options...
September 10, 201311 yr Author comment_431477 Replaced the clutch master and slave with SACHS replacement parts. The old flexible line was in bad shape. Engagement feels much better, but now I can detect clutch slippage. Oh well, I think its time to replace the clutch. Quick question, will the new master and slave cylinders work with the '81-3 280ZX 5-speed? Link to comment https://www.classiczcars.com/forums/topic/47296-clutch-engagement-problem/#findComment-431477 Share on other sites More sharing options...
