gtom Posted August 29, 2013 Share #1 Posted August 29, 2013 Hello again Z community, Ran the motor today on my recently purchased 73 and I hear loud and snapping sounds around the intake and exhaust manifolds. Sound increases when throttle is opened. The car has a history of running hot in stop and go LA traffic. Questions: 1. Does this kind of sound mean that I have an intake or exhaust leak? 2. If it is an exhaust manifold leak, does it mean that my exhaust manifold is warped and needs to be replaced? Thanks much in advance. Link to comment Share on other sites More sharing options...
Virto Posted August 29, 2013 Share #2 Posted August 29, 2013 Check to see if the exhaust manifold nuts are tight. They will work themselves loose sometimes, especially towards cyl 6. I wouldn't worry too much about the manifold being warped just yet.Does sound like it could be backfiring either thru the carbs or the exhaust, though. How do the plugs look? Link to comment Share on other sites More sharing options...
jfa.series1 Posted August 29, 2013 Share #3 Posted August 29, 2013 Be cautious when tightening the exhaust manifold nuts & intake manifold bolts. The max. torque is 8.7 lbs. per the FSM. Link to comment Share on other sites More sharing options...
gtom Posted August 30, 2013 Author Share #4 Posted August 30, 2013 Both systems are original, so they're pretty old. The nuts and bolts look crusty and corroded especially at the exhaust manifold. I don't think it's backfiring because the snapping is constant. But, I'll try to tighten and see what happens.Maybe its time to replace with a header?Thanks again Link to comment Share on other sites More sharing options...
siteunseen Posted August 30, 2013 Share #5 Posted August 30, 2013 (edited) Squirt the crusty stuff with 50/50 Acetone and Automatic Transmission Fluid over and over for a couple of days. That concoction is the best homemade penetrating oil ever. Maybe then they won't snap off, if they do you'll be in deep dew dew (French words). Edited August 30, 2013 by siteunseen Link to comment Share on other sites More sharing options...
madkaw Posted August 31, 2013 Share #6 Posted August 31, 2013 Be cautious when tightening the exhaust manifold nuts & intake manifold bolts. The max. torque is 8.7 lbs. per the FSM.That is FT. Pounds Link to comment Share on other sites More sharing options...
madkaw Posted August 31, 2013 Share #7 Posted August 31, 2013 Sure sounds like an exhaust leak. Link to comment Share on other sites More sharing options...
olzed Posted September 1, 2013 Share #8 Posted September 1, 2013 Don't try to tighten exhaust manifold nuts on a HOT engine. You will almost certainly snap the studs. Link to comment Share on other sites More sharing options...
gtom Posted September 11, 2013 Author Share #9 Posted September 11, 2013 (edited) Decided on a new MSA set up consisting of the coated 6 into 1 headers and premium exhaust. Just arrived. Got the new intake and exhaust stud kit too. Might have a resonator installed at the transmission section later. Hope this system works correctly in the end... Edited September 11, 2013 by gtom Link to comment Share on other sites More sharing options...
ajmcforester Posted September 11, 2013 Share #10 Posted September 11, 2013 Have you checked the valve lashing, timing, and made sure all the emissions parts are working. All these would case what you explained. Link to comment Share on other sites More sharing options...
gtom Posted September 11, 2013 Author Share #11 Posted September 11, 2013 Have you checked the valve lashing, timing, and made sure all the emissions parts are working. All these would case what you explained.Yep, it's not the valves or timing. Car sounds like 'chitty chitty without the bang bang'. As for the emissions parts, I'm sure that's part of the problem. Link to comment Share on other sites More sharing options...
