March 26, 20187 yr comment_545642 Car ran great. No sputtering, nice aceleration! Even better when the pump measured 4.2 psi. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-545642 Share on other sites More sharing options...
March 26, 20187 yr comment_545645 28 minutes ago, jalexquijano said: Car ran great. No sputtering, nice aceleration!  Even better when the pump measured 4.2 psi.  You forgot the happy face emoji , so I added one. Good news. Sounds like we're getting close. The trace of color on the two plugs looks good. I'm told that the darker tan color that we all used to try to achieve is not applicable to modern gas formulas. Were all the plugs about the same color, especially #4?  Please explain "Even better when the pump measured 4.2 psi." You shouldn't notice any difference in the performance whether the fuel pressure is at 3 psi - 4.2 psi. If you have noticed a difference, I would suspect a float needle valve is leaking. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-545645 Share on other sites More sharing options...
March 26, 20187 yr comment_545648 I concur. Looks great!  How does the problematic plug look? Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-545648 Share on other sites More sharing options...
March 26, 20187 yr comment_545687 ill take the 6 plugs out today and will post a picture from left to right 6-5-4-3-2-1 Â Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-545687 Share on other sites More sharing options...
March 26, 20187 yr comment_545691 35 minutes ago, jalexquijano said: ill take the 6 plugs out today and will post a picture from left to right 6-5-4-3-2-1  If you can, hold three together. 1-3 front carb then in another picture 4-6 rear carb. The gas we have around here doesn't get the plugs as dark as the older gas. Mine runs really good finally but the plug's porcelain only gets that good light brown color on about 1/4th that surface. Edited March 26, 20187 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-545691 Share on other sites More sharing options...
March 26, 20187 yr comment_545693 8 hours ago, jalexquijano said: 3.70 turns clockwise spark plugs number 2 and 5 They look like your's! Â I didn't see these. You cost me some money, damn it. I had you at 8 weeks but you got them between 4 & 6. Who had 5Â weeks? Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-545693 Share on other sites More sharing options...
March 26, 20187 yr comment_545694 Should i lower to 3.5?? I think is should leave them like that! Your call! Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-545694 Share on other sites More sharing options...
March 26, 20187 yr comment_545695 You could use this setting as a baseline for a few days and then give the jets a further 1/2 turn down to see if it runs better after you have a feel for the baseline. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-545695 Share on other sites More sharing options...
March 30, 20187 yr comment_546056 Bad news. Sputtering and misfiring started back again even at 3.7 turns clokwise on both front and rear fuel mixture knobs. The car spits as you accelerate at 5 to 6k. Measured the pressure and still 3.2 psi Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-546056 Share on other sites More sharing options...
March 30, 20187 yr comment_546058 Â Not enough info. Spitting as a symptom doesn't tell me squat. Start over with, WAS it ever running good and work your way into WHEN it started to run crappy and WHAT you worked on. This could be something as simple as tightening choke cable clamp, so think about it. Also include driving conditions before and after and your own thoughts on it. Did you ever take a pic of the six plugs? Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-546058 Share on other sites More sharing options...
March 30, 20187 yr comment_546065 It sounds as the carbs are spitting or coughing when cruising over 5k. Sometimes the car even tends to stall but keeps cruising. I even increased the mixture to 4 turns clockwise and it still coughs Edited March 30, 20187 yr by jalexquijano Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-546065 Share on other sites More sharing options...
March 30, 20187 yr comment_546066 Who cruises at 5,000 rpm's? Pressure and flow are different!!!!! Pressure is not the issue!!!! The water going over Niagara falls has low pressure but lot's of flow... If you are running out of fuel it's a flow issue not pressure! Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=34#findComment-546066 Share on other sites More sharing options...
