well it does start but it takes a lot of gas pedal to start. Anyway i cleaned all the plugs with a brass brush before cranking it and drove it slowly with the choke on for 10 minutes. Aceleration is still rough. It misfires a lot and now even with both idle screws at 3,70 turns clockwise whenever you accelerate you can hear the car backfire through the carbs. Major disapointment. I measured the fuel pressure and its still at 3 psi.
Once i returned home, i sprayed carb cleaner to the carbs and intake manifold and did not notice any vacuum leaks. There is something not clear here.
24 minutes ago, jalexquijano said:
How much will you gap them? .31 or .35 or is this irrelevant?
What was the gap on the currently installed plugs?
Dennis
