April 10, 20187 yr comment_547073 13 minutes ago, Jarvo2 said: Should he really even need to use the cold start (choke) in Panama?? I live in Chicago and never need it even in winter Sent from my iPhone using Classic Zcar Club mobile I have a commercial mower that needs choke every time I start it. If I raise up too high off the seat and the kill switch shuts it down while it's hot as can be it still has to choked. I don't understand why, I just know that's what it takes to start it. Maybe the mechanical fuel pump needs the extra pull? My 240 will crank without choke though but it lives in a garage that never too cold. I use the choke regardless just to get the oil pressure up faster. When the oil pressure gets 3/4 gauge I push the choke off. By the time I get the PITA seatbelt fastened it's good to go. Maybe Jalex's hot rod motor needs the extra fuel? Way more questions than answers in this thread. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547073 Share on other sites More sharing options...
April 10, 20187 yr comment_547076 Maybe more fuel flow. Fuel pump psi is not working for me. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547076 Share on other sites More sharing options...
April 10, 20187 yr comment_547079 1 hour ago, siteunseen said: Way more questions than answers in this thread. Can I hear an Amen, Brothers & Sisters? Dennis Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547079 Share on other sites More sharing options...
April 10, 20187 yr comment_547083 @jalexquijano Are you touching the throttle when trying to start it cold with the choke on? One of your previous post suggested this... Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547083 Share on other sites More sharing options...
April 11, 20187 yr comment_547092 7 hours ago, Lumens said: Good grief. I thought this carb issue was solved already. Anyway, if I remember, you were running a Pertronix ignition setup. Use their gap. not stock gap. Now I see you are talking about your magnetic pick up gap. I am talking about spark plug gap as recommended by that Company. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547092 Share on other sites More sharing options...
April 11, 20187 yr comment_547096 When I'm wrong it's way wrong, nobody can say I'm a half arse. My mower has a vacuum fuel pump! That's why I have to use the choke every time. I never thought of that since the first one I bought in '06. Stupid stupid stupid. I'm out of here, it's past my bedtime. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547096 Share on other sites More sharing options...
April 11, 20187 yr comment_547097 15 minutes ago, Lumens said: Now I see you are talking about your magnetic pick up gap. I am talking about spark plug gap as recommended by that Company. All plugs came out like this due to driving the car with full choke on to avoid misfire Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547097 Share on other sites More sharing options...
April 11, 20187 yr comment_547103  Of course it looks that way. With the choke on the fuel mixture is mega-rich. The reason I want you to put in new plugs and start it with NO CHOKE is I suspect that you're using too much choke and fouling the plugs before you ever get on the road. Yes the engine will lack power while it's warming up. Just baby the throttle and keep it running (with no choke) until it's warmed up, then take it for a drive. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547103 Share on other sites More sharing options...
April 11, 20187 yr comment_547110 Err Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547110 Share on other sites More sharing options...
April 11, 20187 yr comment_547111 This is really weird. I swapped all the 6 spark plugs with a brand new ngk bp6es set and sprayed and cleaned the distributor cap, rotor and inner with deoxit d5. Viola! No more sputtering and coughing during the spin. No more rough accelaration. Just perfect. What could have been the cause??? Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547111 Share on other sites More sharing options...
April 11, 20187 yr comment_547112 Too much carbon on your plugs. You fouled them. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547112 Share on other sites More sharing options...
April 11, 20187 yr comment_547115 1 hour ago, 240260280 said: Too much carbon on your plugs. You fouled them. Fouling the plugs damages them? No way to save them by brushing them with a brass brush? Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=46#findComment-547115 Share on other sites More sharing options...
