jalexquijano Posted May 19, 2018 Share #577 Posted May 19, 2018 They are not sooted up. They sooted up in the past. I will drive it in light traffic today to see what happens Link to comment Share on other sites More sharing options...
Mark Maras Posted May 20, 2018 Share #578 Posted May 20, 2018 @jalexquijano Is there much difference in spark plug color when you compare #s 1-3 vs 4-6? Let's try to figure out if one carb is running richer than the other. 1 Link to comment Share on other sites More sharing options...
jalexquijano Posted May 23, 2018 Share #579 Posted May 23, 2018 Ill test it today! Link to comment Share on other sites More sharing options...
siteunseen Posted May 24, 2018 Share #580 Posted May 24, 2018 (edited) 3 hours ago, jalexquijano said: Ill test it today! Yes, you should disable one carb at a time and adjust them. My favorite is Philip's "equally s h i t t y" Edited May 24, 2018 by siteunseen 1 Link to comment Share on other sites More sharing options...
jalexquijano Posted May 24, 2018 Share #581 Posted May 24, 2018 Dont know how to do this. If you show me i can try. You mean closing the idle mixture knob fully? Please explain step by step approach Link to comment Share on other sites More sharing options...
siteunseen Posted May 24, 2018 Share #582 Posted May 24, 2018 (edited) Google "quick and dirty su tuning classiczcars.com" Print it and don't throw it away. Edited May 24, 2018 by siteunseen 1 Link to comment Share on other sites More sharing options...
jalexquijano Posted May 27, 2018 Share #583 Posted May 27, 2018 On 5/20/2018 at 10:46 AM, Mark Maras said: @jalexquijano Is there much difference in spark plug color when you compare #s 1-3 vs 4-6? Let's try to figure out if one carb is running richer than the other. Just took a 20 min ride along the highway at 6pm and a couple of fast traffic lights. Parked the car and pulled out plugs number 5, 2 and 4. Plug 4 now looks a little darker than 5 and 2. Link to comment Share on other sites More sharing options...
Mark Maras Posted May 27, 2018 Share #584 Posted May 27, 2018 They don't look too bad although #4 is still the odd one. I think I'd try swapping #4 plug wire with another wire to see if the problem moves with the wire. What is your over all impression of the way it's running? Any problems idling for long periods of time? If I was running your engine build, I would expect to have to blip the throttle now and then to clear the plugs at idle. Backfiring in the intake or exhaust? Misfiring at any RPM? 1 Link to comment Share on other sites More sharing options...
jalexquijano Posted May 27, 2018 Share #585 Posted May 27, 2018 No backfiring either through the intake or exhaust whatsoever. Running nice. I was wondering if before inspecting the plugs i should run the car hard and then shut it down and not as i am doing driving the car around accelerating every now and then, couple of stops on traffic lights and inspecting after parking the car in the garage. Link to comment Share on other sites More sharing options...
Mark Maras Posted May 27, 2018 Share #586 Posted May 27, 2018 You want it to run best under normal driving conditions which, I'm assuming, is a daily driver. It sounds to me like it's running pretty darned good. No need to go out and run the engine hard just to check the plugs. You can, however, go out and run it hard to have fun. As long as you share your fun with us. Pics are nice, videos are better. I'd like to hear it run. 1 Link to comment Share on other sites More sharing options...
Patcon Posted May 27, 2018 Share #587 Posted May 27, 2018 1 hour ago, jalexquijano said: No backfiring either through the intake or exhaust whatsoever. Running nice. I was wondering if before inspecting the plugs i should run the car hard and then shut it down and not as i am doing driving the car around accelerating every now and then, couple of stops on traffic lights and inspecting after parking the car in the garage. If it ain't broke, don't break it!!! Link to comment Share on other sites More sharing options...
siteunseen Posted May 27, 2018 Share #588 Posted May 27, 2018 I agree, enjoy the car now that YOU have set the float levels (with Marks help-THANK YOU MARK). If you look for problems they'll show up, real and imagined. I can't remember what oil you're using in the SUs but I'm thinking in a hot climate one is the best. Don't know but I'm hoping someone can tell you. Maybe ATF would be be best? But I haven't a clue. I run the 20 weight 3in 1. 1 Link to comment Share on other sites More sharing options...
