1972 Float Adjustment ...
240Z240Z240Z
@jalexquijano I'm assuming you mean it won't start without using the choke? Will it start using 1/2 choke or even 1/4 choke? You may not need full choke to start it. Too much choke, even for a few minutes, can carbon up the plugs and exhaust. How well is running these days when it's warm? Any more problems with #4 or did the cap and rotor fix it?
6 hours ago, Mark Maras said:
@Lumens He didn't mention #4 still having problems. I asked about #4 just to satisfy my curiosity.
I know. We both typed a reply at Exactly the same time. I saw yours after I submitted mine.
Bad #4 cylinder plug.. No compression test report on it. All rest of cylinders were reported at 100 psi.
Does not compute.
On 2/6/2018 at 4:01 PM, jalexquijano said:
Where do i purchase a new set of high quality needle valves for my 3 screws su carbs?
4 1/2 year necro post started it all.  4 1/2 months and 26 pages later...it continues.  The internet.
  • Haha 1
Thanks guys. I took the car out for a spin yesterday after performing the following:
1.  pulled the choke to 1/2 the lever in order for the car to crank.
2. Let the car warm for a minute after taking it out from the garage.
3. Drove it gently until the temp needle got near to 1/2
4. Started stepping on the gas to achieve more speed.
Results:
1. No backfire either on the intake or exhaust.
2.  Cruises nice although i would prefer a faster response when accelarating from 1st gear. How can i accomplish this or is it the nature of the beast?
Will pull all 6 plugs out today.
