March 11, 20187 yr comment_544280 "turn up" and "turn down" work nicely for SU jet height nuts and Weber Idle Enrichment Screws. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544280 Share on other sites More sharing options...
March 11, 20187 yr comment_544284 In and out, up and down are nozzle terms I'm used to but, I'm a man. I can change. If I have to. I guess. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544284 Share on other sites More sharing options...
March 11, 20187 yr comment_544291 I'm fairly sure having this conversation will be helpful somehow. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544291 Share on other sites More sharing options...
March 11, 20187 yr comment_544297 At least now i know that the carbs can work with 3 psi. I can move on and continue adjusting the floats by narrowing the gap until i reach to 2.5 turns. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544297 Share on other sites More sharing options...
March 11, 20187 yr comment_544304 Congratulations, we're getting close. Keep in mind the goal is NOT to get it to run well at 2 1/2 turns. The goal is to get the floats set to 2 1/2 turns THEN adjust the mixture screws to fine tune it. The float level at 2 1/2 turns down (clockwise) is the primary mixture adjustment. We've got to get the floats right before we can fine tune. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544304 Share on other sites More sharing options...
March 11, 20187 yr comment_544321 Ok. I get your point. Do you think that when the psi was at 4 to 4.3 psi it could have affected the car performance in any way? Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544321 Share on other sites More sharing options...
March 11, 20187 yr comment_544323 On 9/3/2018 at 8:23 PM, Mark Maras said: Could idle speed be the problem? I think it may be contributing to the plugs loading up during a long idle. I want to get the carbs tuned to rule out that possibility. In my youth, when everyone was stuffing big cams into small block Chevys, one of the negatives was having to blip the throttle to clear the plugs when the idle started dropping. I didn't think Jalex's cam had enough duration or overlap to make it idle that rough but IF the idle is supposed to be up around 1200 rpms, it would indicate that it is a rough idling cam. @jalexquijano After the engine is warmed up, what is the RPMs at idle. A few historical questions. I believe you changed cams to try alleviate a problem earlier. What was the problem? Did the cam change help? Was there ever a time (even briefly) when the engine ran good or have there been problems since day one? Mark, At least you clearly understand my car's problem. Spark plugs turning black when idling for long time. Spark plugs turn black and when accelrating engine sputters until the spark plugs clear again. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544323 Share on other sites More sharing options...
March 11, 20187 yr comment_544326 Jalex. We're "getting there". I'll bet you're starting to feel a sense of accomplishment. You may even have a stupid grin on your face that can't be erased. VOE. Soon you'll be giving your former mechanics a single digit salute as you drive by their shops, revving the engine to 5000 + RPMs. Keep up the good work. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544326 Share on other sites More sharing options...
March 11, 20187 yr comment_544328 With help from people like Mark I've come to realize I like working on mine more than driving it. Fixing problems gives me that sense of accomplishment unlike driving one. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544328 Share on other sites More sharing options...
March 12, 20187 yr comment_544432 Mark you are the best. Ill keep working on my float adjustments. Today ill crank the car at 3.5 turns and verify the level. Here i found a picture of how they were adjusted from ztherapy when sent by mail supposedly at 2.5 turns. I noticed the float is not fully straight but inclined. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544432 Share on other sites More sharing options...
March 12, 20187 yr comment_544435 Yeah, inclined is what I remember. You can check the level at 3 1/2 turns but remember the level is supposed to be at 2 1/2 turns. If you're having trouble seeing the fuel level at 2 1/2 turns, pull the choke. That will pull the nozzles down and you will be able to see how low the fuel level is and hopefully, how far it has to come up. Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544435 Share on other sites More sharing options...
March 12, 20187 yr comment_544436 Sounds like Jalex's next challenge will be how to get Mr. Maras a case of his favorite brand Link to comment https://www.classiczcars.com/forums/topic/47304-1972-float-adjustment/?&page=25#findComment-544436 Share on other sites More sharing options...
