Recently Browsing 0
I just created a "redirect" in our server so that all addresses opening 240z.org will automatically change to classiczcars.com.
This isn't a big deal and all links should still work. But, some users may complain because you will need to save another cookie to your computer. The 240z.org cookie can be deleted because all cookies are now stored as classiczcars.com.
If this is all a foreign language to you... just log-in to the system if it asks you again. You should be ok from that point on.
I finally figured out how to make a redirect work properly.
We still own two domains. But, we no longer have the problem of two different domains pointing to the same directory. The system now sees the old domain and then REDIRECTS it to our main domain name.
All old links should still work. Meaning, if you want to jump directly to the gallery, just use http://www.240z.org/photopost. You'll see that the link is automatically changed to http://www.classiczcars.com/photopost in the address bar.
-- Mike
https://www.classiczcars.com/forums/topic/4731-cookie-password-domain-stuff/Share on other sites
