December 5, 201410 yr comment_459920 Set the fuel to 27mm down from the ledge where the jets fit. Here is a guide. Just ignore the 25mm and go for 27mm. http://www.classiczcars.com/topic/44512-setting-weber-dcoe-fuel-level-with-caliper/ Link to comment https://www.classiczcars.com/forums/topic/47318-73-240z-with-triple-side-draft-weber-carbs/?&page=2#findComment-459920 Share on other sites More sharing options...
