Posted September 17, 201311 yr comment_431825 My #1 carb is getting wayyy too much gas. I have posted the following video to demonstrate what it is doing:SU Carb - YouTubeThe #2 carb seems to be getting the right amount of fuel. I mean I don't see it flowing out like a geyser like the #1 carb is. I initially thought that the regulator was bad (i have an aftermarket electric pump), however since the #2 seems to be working right, I'm thinking something may be wrong with the #1 carb. Hope someone has some answers.Thanks. Link to comment https://www.classiczcars.com/forums/topic/47431-1-carb-a-geyser/ Share on other sites More sharing options...
September 17, 201311 yr comment_431836 The float valve is more than likely stuck open. Try giving the side of the carb bowl a few taps with a wrench. If that doesn't work, remove the float bowl and check the valve.It may have some gunk trapped under it.Also check the float for fuel leaking into it. Edited September 17, 201311 yr by olzed Link to comment https://www.classiczcars.com/forums/topic/47431-1-carb-a-geyser/#findComment-431836 Share on other sites More sharing options...
September 17, 201311 yr comment_431839 What olzed said. Link to comment https://www.classiczcars.com/forums/topic/47431-1-carb-a-geyser/#findComment-431839 Share on other sites More sharing options...
September 17, 201311 yr comment_431843 As mentioned, you can have some garbage getting by the final filter holding the needle open, OR maybe the float has gotten tweaked holding it in the down position. The last is unlikely but pulling the float bowl lid will show it if it's a problem. If it's grit, then opening up and getting the final filter (inside the hump on the lid) and cleaning it would be a next step. New washers for the banjo fitting would be nice to have on hand as they tend to not reseal well. Link to comment https://www.classiczcars.com/forums/topic/47431-1-carb-a-geyser/#findComment-431843 Share on other sites More sharing options...
