Posted September 21, 201311 yr comment_432133 I have all the parts I need to convert my daily driver 280z from 5 speed to Automatic transmission except for high & low pressure cooling "tube/pipe" that run between left side of trans to bottom of radiator. If anyone has them, please call or text me at 310 308 8985. I am in L. A. Area.They are not even on Ebay as pretty much everyone through away Automatic transmission parts after converting to Manual transmission.:disappoin Link to comment https://www.classiczcars.com/forums/topic/47467-help-need-automatic-transmission-cooling-pipes-needed/ Share on other sites More sharing options...
September 21, 201311 yr comment_432135 like you mentioned. I think everyone throws them away. Your probaby a loner doen a reverse conversion. My I ask why you are changing the 5spd for an auto?You might be better off making new ones. The originals often rub against each other an becaome very thin to the point where they can leak and thats 35 years of rubbing.Goodluck with the swapChas Link to comment https://www.classiczcars.com/forums/topic/47467-help-need-automatic-transmission-cooling-pipes-needed/#findComment-432135 Share on other sites More sharing options...
September 21, 201311 yr Author comment_432149 My number is 310-308-8986 Sorry,,,,,, Link to comment https://www.classiczcars.com/forums/topic/47467-help-need-automatic-transmission-cooling-pipes-needed/#findComment-432149 Share on other sites More sharing options...
September 22, 201311 yr comment_432167 I might have some in the future - don't know when so it's not much help. My aluminum 3-row has AN fittings welded on for the trans lines, thinking of going with the steel braided hydraulic hose (with the cloth braided cover) from the trans to the radiator to eliminate leaks. Got some other projects first, though. Link to comment https://www.classiczcars.com/forums/topic/47467-help-need-automatic-transmission-cooling-pipes-needed/#findComment-432167 Share on other sites More sharing options...
