wheel spacer and konig rewinds
malibud
I put Toyota calipers on the front and my rewinds will not clear I tried 5mm washers so I getting 5mm spacers looks like it will work , Question do I get the spacers for all 4 wheels or just the front/ I am leaning toward all four any suggestions would be helpful.
thanks
thanks
I have a couple of sets of spacers in my attic from the racing days.
Spacers - Summit or JEGS has them - you may have to take them to a machine shop and have them ground down - 1/4" may be all you can find out there and you may just need 1/8" clearance. You will have to get some longer stud bolts as well to make it work - NAPA has them - take your stud to the parts counter and get one size longer - make sure you get the same thread.
Did you go vented rotors or solid?
I am using the stock solid rotors. I tried to measure by using washers and best I can tell 5mm will clear it but they only come in 61mm hub size should fit the back (i ordered all 4) but am going to have machine the front ones. Best I can tell it will need to be 73mm for the front. would like to get as close to hubcentric as I can. Can anyone confirm the front size ? I am going to go out there and measure with a string and divide by 3.14 and see what happens . Thanks for the offer Jerry but i already ordered them.
14 and 15" Konig will not clear Toyota calipers without spacers I tried both . I think with 5mm i can get about 5-6 turns on stock stud bolts should be OK a think
Dan
update i am a dumb A. i put the the calipers on and finally realized that they are s12W and are made for vented rotors . got the s12+8 all is good no spacers . would make someone a good deal on some a good deal on some s12W calipers and almost mew EBC green stuff pads . got them on ebay . thanks for the help.
  • Who's Online   1 Member, 0 Anonymous, 370 Guests (See full list)
