Need help with speedo pinon gear!!!
mjr45
My speedo quit working the other and I noticed some oil around the pinion gear. I tried to loosen the speedo cable and the pinion gear just pulled out of the tranny because the little ear piece was loose and ahd turned. I know there are O rings and seals for the gear and the cable, but can't find and diagrams to show where they go, the only one I know for sure( also the only one I found) is the O ring around the gear holder. I need to replace the black gear as its sorta chewed up. The tranny is a 79 Z 5 speed and the cable is the stock 75. I need a diagram of some sort to know what goes where and I can't find it in the FSM. Any help would be greatly appreciated, thanks.
Thanks Carl, where did you find that? I got the O ring covered but not real sure about the oil seal part #60. MSA has a large and a small O ring, is the oil seal actually an O ring? I assume it goes into the pinion gear housing or does it go over the end of the cable? I looked at that thread and it has good pics of the parts all layed out, but none of them put together. Thanks again.
Edited by mjr45
I have purchased one of these a few years ago from the same vendor - worth every penny. You may want to grab it while you can. It will pay for itself quickly - just give the item code to your Nissan dealer and if it is still being made you will not have to go to MSA anymore - my parts manager gives me his body shop rate.
Datsun S30 240Z 260z 280z Fairlady LH Parts Catalog 1977 USA Canada Model | eBay
  • Who's Online   2 Members, 0 Anonymous, 478 Guests (See full list)
