Email logins are now active ×
compression readings
anthony_c
I'm not an expert on Z cars but engines are engines (more or less).
I had a freshly rebuilt 1956 Cadillac engine that burned some oil at first. I was somewhat concerned (as you are) but all the compression tests checked out and there were no other symptoms or noises or anything else out of the normal range.
After driving it for 500 or so miles - serious driving like 100 mile trips, 80+ mph, rapid acceleration, etc. (no babying) - the oil smoke puffs diminished and finally stopped all together.
I believe the piston rings just needed to work their way into a comfort zone.
  • 3 weeks later...
