Not sure this would help or would work with PMs but if you click on my profile in the upper right of the screen, then click on settings at the upper right, then click on edit ignore list which is on the far left of the screen fairly far down you should be able to add a user to the ignore list. I always had assumed it just blocked their posts but maybe it works on PMs too. FWIW.
