SCPMAN148 Posted October 6, 2013 Share #1 Posted October 6, 2013 I have a 1976 stock 280z. I'm trying to get my blower fan working. I opened the fuse box today and found a broken clip on the A/C fuse. How do I find a replacement and would that make the blower not work? Link to comment Share on other sites More sharing options...
SteveJ Posted October 6, 2013 Share #2 Posted October 6, 2013 1. I haven't tried to find a fuse box clip. You might try some of the local marine stores. I figure there should be some in Myrtle Beach.2. Yes. Link to comment Share on other sites More sharing options...
djwarner Posted October 6, 2013 Share #3 Posted October 6, 2013 I had a defective clip on my series I 240z. Ended up getting a single station fuse holder from Radio Shack. I carefully sectioned out the defective clip and squared the hole I made with a Dremel tool. Carefully cut the new fuse holder apart and fitted it into the newly made hole. Epoxied in the new clip and soldered in the lead. Hard to detect with the fuse cover on, but there if you look for it.So yes it can be done, but it won't pass for a concourse restoration. Link to comment Share on other sites More sharing options...
SteveJ Posted October 6, 2013 Share #4 Posted October 6, 2013 I also found this on Amazon: 50 Pcs 6 X 30mm Electronic Glass Fuse Tube Clip Clamp: Amazon.com: Industrial & Scientific Lifetime supply. Link to comment Share on other sites More sharing options...
SCPMAN148 Posted October 6, 2013 Author Share #5 Posted October 6, 2013 Thanks for your help. I'm going to try to find a new clip here in town first. I found a fuse box on Ebay that has the same clip. Link to comment Share on other sites More sharing options...
