Posted October 15, 201311 yr comment_433759 i am in need of an a/c pressure switch for my 74 with factory air. If you have happen to have or know of a 74 parts car hanging about, it looks like an aluminum cylinder, approx 1" in diameter and 1" long, with a two-wire pigtail attached to it. The switch threads into the top of the receiver/drier which is located aft of the voltage regulator and shunt. the one in the photo is missing its wires. thanks for your help, tony Edited October 15, 201311 yr by awconroy Link to comment https://www.classiczcars.com/forums/topic/47713-74-ac-parts/ Share on other sites More sharing options...
October 16, 201311 yr Author comment_433813 35 views and no replies. ohhh, this doesn't look promising. Link to comment https://www.classiczcars.com/forums/topic/47713-74-ac-parts/#findComment-433813 Share on other sites More sharing options...
October 16, 201311 yr comment_433863 I'm debating removing my A/C & if I do you can have the switch !. I'm wondering whether you may be dissapointed with the A/C once you getit up & running. I live in the NE & only had need for it on a few really hot day's. When I'm asked to describe how cool it is I say just enough for me to close the windows & prevent me from sweating (just). Things have moved on in 40 yrs....also the compressor alone must weigh ~ 50lb's Link to comment https://www.classiczcars.com/forums/topic/47713-74-ac-parts/#findComment-433863 Share on other sites More sharing options...
October 17, 201311 yr Author comment_433875 that would be appreciated. summers here in richmond commonly run 95 degrees with 90% humidity so anything helps. it was working until recently, so i am familiar with how anemic it is. to paraphrase jeremy clarkson, it blows with all the force of an asthmatic mouse. Link to comment https://www.classiczcars.com/forums/topic/47713-74-ac-parts/#findComment-433875 Share on other sites More sharing options...
