77 280 z 2+2 won't drive
Andy@hardy
The key concept of the EFI system is fuel pressure. The gauge seems expensive but the $40 will probably save you hundreds in parts and whatever your time is worth. If you don't want to buy one, see if a shop will measure it for a small fee, or if you can borrow one. There's no need to "cut in" a fitting for a gauge. The gauges come with a T fitting with the gauge port, a piece of hose and some hose clamps. All you have to do is pull the hose between the fuel rail and the filter and insert the T fitting. If you replaced the filter, you've already had the hose off once.
Avoiding the fuel pressure measurement might be the most common (non)action of people new to working on EFI. Fuel squirts from the hose, gas flows, the pump makes noise - none of these tell that fuel pressure is right. If it's not right, the EFI can not work as intended.
