Posted October 26, 201311 yr comment_434505 I just got my rebuilt frame up restoration home...what type of gas are y'all using for 1972 240Z ? Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/ Share on other sites More sharing options...
October 26, 201311 yr comment_434508 If you are going to look a lot, drive a little, non-ethanol regular will serve you well. Can usually be found at marinas at a 60-70 cent per gallon more than premium. Do you know if the head was rebuilt for non-leaded gas? If not, there are supplements for that as well. Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434508 Share on other sites More sharing options...
October 26, 201311 yr Author comment_434509 The head was definiitely not rebuilt... Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434509 Share on other sites More sharing options...
October 26, 201311 yr comment_434510 My 73 came with an owner's manual, it says to use 96 octane. I remember a post about how 70's octane ratings are different from today. It didn't ping with 89 octane until I put a 81 JDM head on it, now it's set up for CA 91 octane, I think it likes Arizona 92 or 93 better though. Could be my imagination. I advance the timing slightly when I'm there. Wish I knew more about timing adjustments for various gasolines.Maybe a valve job? They'll put better valve seats, and performance should improve. Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434510 Share on other sites More sharing options...
October 26, 201311 yr comment_434512 You can get the lead replacement just about anywhere, even Wally World.As for gas, the octane ratings back then used a different method. Today's 89 octane fuels should run just fine.Here is a source for non-ethanol fuels:Ethanol-free gas stations in the U.S. and Canada Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434512 Share on other sites More sharing options...
October 26, 201311 yr comment_434519 What the FSM recommends is equivalent to today's 87. Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434519 Share on other sites More sharing options...
October 26, 201311 yr comment_434531 The lowest we have here in Europe is 92 ( Germany only ) and 95 octane, and the highest 102 octane in Germany also. But I believe the manual says 95 minium. My 71 runs fine on 95... But maybe they came with lower compression heads in the US, and you can use lower octane fuel... I don't know. Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434531 Share on other sites More sharing options...
October 26, 201311 yr comment_434537 I use super only. 93 in Ga. Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434537 Share on other sites More sharing options...
October 26, 201311 yr comment_434540 That depends on where the timing is set. I run nothing but 93 octane. Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434540 Share on other sites More sharing options...
October 26, 201311 yr comment_434547 With my vaccum advance hooked up my car prefers 93 to 94 octane. It will ping on anything below 92. Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434547 Share on other sites More sharing options...
October 27, 201311 yr comment_434578 bartsscooterservice said: The lowest we have here in Europe is 92 ( Germany only ) and 95 octane, and the highest 102 octane in Germany also. But I believe the manual says 95 minium. My 71 runs fine on 95... But maybe they came with lower compression heads in the US, and you can use lower octane fuel... I don't know.Octane is calculated differently in the US and Canada versus Europe. Generally, the numbers over here are 4-5 points lower than those in Europe. (Here's a Wikipedia article that explains the difference.) So, your 92 is comparable to our 87. Link to comment https://www.classiczcars.com/forums/topic/47798-gasoline/#findComment-434578 Share on other sites More sharing options...
