Posted February 20, 200322 yr comment_27299 My brakes work great, after I pump them once. Just once is all it takes. I have tried to bleed them several times but the still have to be pumped. Can anyone help me?Frankenstein Z Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/ Share on other sites More sharing options...
February 20, 200322 yr comment_27313 Once again we need more specific info.Tried to bleed them?What does that mean?The better the question the better the answer. Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-27313 Share on other sites More sharing options...
February 20, 200322 yr comment_27325 I would try a vaccuum type bleeder. It will help keep ALL the air out.-Don't pet a burning dog... Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-27325 Share on other sites More sharing options...
February 20, 200322 yr comment_27326 Did you try bleeding the master cylinder, I don't know about all Zs but when I replaced brake lines on my 77 had the same problems. It's the only car I've ever bleed that has valves on the master cylinder. Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-27326 Share on other sites More sharing options...
February 20, 200322 yr Author comment_27332 I have never bled the master cylinder, I didn't know you could. I also heard that the brake lines themselves could be the problem. I have heard of a vaccum bleeder, but if the lines are letting air in would that still help?Frankenstein Z Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-27332 Share on other sites More sharing options...
February 20, 200322 yr comment_27339 Well, I've posted this before but you should always bleed the master cylinder before you bleed the wheel cylinders. When you add fluid to the master, if there is any trapped air when you add the fluid, it may not get all the way to the wheel cylinders when you bleed the cylinders. Therefore, you have introduced air into the system while you are trying to do the opposite, and have defeated your own purpose. If, after a proper bleeding, you still have to pump the brake pedal, I would suspect you have a bad master cylinder, barring any leaks in the system such as a wheel cylinder or brake line. Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-27339 Share on other sites More sharing options...
February 21, 200322 yr comment_27408 If the rubber brake lines have never been replaced or your not sure if they have--ITS TIME.If the rear wheel cylinders have not been replaced there is a good chance thats your problem.I would suggest replacement of them instead of the rebuild kits.If the brake shoe adjusters on the rear wheel cylinders is not working the first pump could be putting the shoe in proper position,the second puts it against the drum and makes you stop.When the brake is at rest the shoe pulls back to the "too far" position.Then you must double pump again. Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-27408 Share on other sites More sharing options...
February 21, 200322 yr Author comment_27417 Thanks for the explanation guys, I will put it to good use.Thanks AgainFrankenstein Z Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-27417 Share on other sites More sharing options...
February 28, 200322 yr comment_28147 I've got the same problem with double pumping the brake pedal. I also have a problem which, I think, is associated with Servo unit. When the power comes off the brake pedal goes down a long way before engaing. I'm connecting this with a fault in the servo unit pressure. Would this be correct?? Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-28147 Share on other sites More sharing options...
March 1, 200322 yr comment_28192 Saint, has it done this ever since you got the car back? Does the pedal firm up with a second pump on the brakes? I'm wondering if you possibly just need a good bleeding again, perhaps there was some trapped air somewhere and it is now moved to one of the wheel cylinders and/or pistons and is causing the soft pedal. Did they bleed the master thoroughly before they bled the brakes themselves I wonder? Most of the time, a problem with the Master Vac will cause a harder pedal due to less assist and you will be standing on the pedal to get the brakes to work, like driving a car with no power brakes at all. When you say the brakes get worse when the power is off(idle?), I'm also wondering if maybe you just have something as simple as a vacuum leak to the Master Vac.....but that would also make it stiffer not softer... Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-28192 Share on other sites More sharing options...
March 2, 200322 yr comment_28318 Yes to both questions. Thanks for the advice though, I'll go for the master cylinder bleed and see if it improves. Cheers Link to comment https://www.classiczcars.com/forums/topic/4781-my-brakes-suck/#findComment-28318 Share on other sites More sharing options...
