Starting a new project...Subaru STI Differential swap into my Z
You might have to search the threads on Hybridz for that. They were having a tough time coming up with those. I used the ones from my old axles without reservation. Not sure if I have ever read about a failure on one of these bolts.
Edited by madkaw
because
I read through the thread and, actually, the studs just seem to be difficult to find. Dtsnlvrs reported in Post #242 that the part number, 38228-21000, does work and can be found. In #245 you found 12. So it comes down to luck or, hopefully, Nissan made more. Somebody talked about Nissan having a vendor make more so maybe they've restocked by now. I forgot to note which post and got tired of reading so can't say who said that. Post #257 reports an option using hex heads.
Maybe a design revision would be in order to allow the use of readily available studs. It's Wolf Creek's program now, maybe someone can send a prompt.
By the way, somebody had "whine" in Post #273, although it was just one of several. But, reconsidering everything, the OBX option seems to score a few more points in the viability contest.
Subaru WRX STi R180 Side Axles - Vendor's Forum - HybridZ
  • Who's Online   1 Member, 0 Anonymous, 230 Guests (See full list)
