440cc Not modified 280z... could it work ?
cesar280z
The ECU is designed to work with 188 cc injectors. With 440's the ECU will be injecting over twice as much fuel as needed, if they opened properly. Those are probably high impedance resistors so you'd have extra resistance in the circuit with the stock dropping resistors and they might not open correctly. If they did open properly, you'd have a very very rich mixture. If the engine even started it's doubtful that it would run once it warmed up.
