dpascual1986 Posted October 31, 2013 Share #1 Posted October 31, 2013 Did anyone have a hard time fitting their turn signals on this air dam? The air dam's contours doesnt seem to fit the turn signals very well. Any tips or tricks that you did? Its on a 73 240zMotorsport! Urethane Air Dam, With Brake Cooling Ducts, 70-8/74 240Z-260Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts Link to comment Share on other sites More sharing options...
dpascual1986 Posted November 3, 2013 Author Share #2 Posted November 3, 2013 (edited) I figured it out.. heres how..1. Remove air dam from car2. Install the turn signals, twisting the air dam as needed. 3. Apply heat from a heat gun (only to the turn signal area so the air dam would retain its shape) to soften the air dam material to release the tension from the turn signal light install.4. Let cool to retain its new shape.5. Install air dam on car6. Enjoy :-) Edited November 3, 2013 by dpascual1986 Link to comment Share on other sites More sharing options...
Patcon Posted November 9, 2013 Share #3 Posted November 9, 2013 Good idea, very sharp. I will be doing this soon. Thanks for the tip...Charles Link to comment Share on other sites More sharing options...
