Posted November 9, 201311 yr comment_435738 I picked up a 1983 280ZX distributor the other day, I've had it apart and it seems to have very little wear so cleaned it up and re greased. Now I have a 240z with an L28 with triple carbs and I have read many times that what I need is an E12-80 ignition control module. My question is why? Why can't I use this one? I know it's FI but what would that have to do with the timing of the spark? Thanks, Chris Link to comment https://www.classiczcars.com/forums/topic/47930-280zx-distributor-control-module/ Share on other sites More sharing options...
November 9, 201311 yr comment_435741 You can use that module, just hook up the top connector only. The connection at the bottom/side is a timing retard- which you don't need.The advance numbers are the same as the 1280 dizzy Link to comment https://www.classiczcars.com/forums/topic/47930-280zx-distributor-control-module/#findComment-435741 Share on other sites More sharing options...
November 10, 201311 yr comment_435747 What you might want to double-check is the timing advance curves. Later engines were designed for high fuel mileage and emissions so have a lot of vacuum advance. I copied some entries from the Excel chart.The numbers are initial, centrifugal, vacuum, total of all three (high PRM cruising), RPM at which centrifugal is complete, total of initial plus centrifugal (full throttle above indicated RPM).D606-52 17 12 11 40 2000 29 M/A 1970 – 1972D611-54 7 24 14 45 2830 31 M 1973D6K82-01 8 17 30 55 2800 25 M/A 1983 Non-Turbop.s. Mike, we need WYSIWYG! I spent 5 minutes making it look right and formatting disappears when posted. Edited November 10, 201311 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/47930-280zx-distributor-control-module/#findComment-435747 Share on other sites More sharing options...
November 10, 201311 yr comment_435751 I guess I assumed he wouldn't be using vacuum advance with his set -up.ID shoot for 20 initial and see how it runs-NO vacuum advance Link to comment https://www.classiczcars.com/forums/topic/47930-280zx-distributor-control-module/#findComment-435751 Share on other sites More sharing options...
November 10, 201311 yr comment_435752 I forgot that from the other thread. No vacuum advance. 20 + 17 puts him at 37. He had 30 degrees total in that thread, post #13, but didn't report how it drove. New distributor implies that there's still pinging. Maybe? Link to comment https://www.classiczcars.com/forums/topic/47930-280zx-distributor-control-module/#findComment-435752 Share on other sites More sharing options...
November 10, 201311 yr Author comment_435767 No I don't get to try her out on the road until next spring, the township has already started laying down salt on the roads.The body is completely sealed up after the restore but I just can't bring myself to do it. Our daily drivers only last about 10-12 years up here before they are swiss cheese.I thought 1983 dizzy might be good because the static timing is 3 degrees higher and centrifugal advance is 7 degrees less, trying to give myself some options for the spring when I start to dial this engine in. Also if the the Pertronix unit goes then I have a back up distributor.Thanks guys,Chris Link to comment https://www.classiczcars.com/forums/topic/47930-280zx-distributor-control-module/#findComment-435767 Share on other sites More sharing options...
November 10, 201311 yr comment_435779 Well static timing is where you set it at. You don't need to set it at factory specs.The ZX dizzy works out well for high initial timing( good for triples) and not too much mechanical advance. If someone had the time and energy you could work with the vacuum advance and limit the amount it draws in. As it is, it's just too much to use on the ZX dizzy and still run full 36-38 degrees advance for best power.thats why I can't wait to have ECU controlled ignition Link to comment https://www.classiczcars.com/forums/topic/47930-280zx-distributor-control-module/#findComment-435779 Share on other sites More sharing options...
November 10, 201311 yr comment_435786 The vacuum advance does have an adjustable limiting screw under the plastic sealant/locker. Link to comment https://www.classiczcars.com/forums/topic/47930-280zx-distributor-control-module/#findComment-435786 Share on other sites More sharing options...
