Posted November 13, 201311 yr comment_436015 Need help identifying a wire - Yellow with green stripe coming from the same wire bundle where the window washer pump wires are. Daniel Link to comment https://www.classiczcars.com/forums/topic/47956-73-240z-yellow-and-green-wire-coming-from-the-winshield-washer-wire-bundle/ Share on other sites More sharing options...
November 13, 201311 yr comment_436024 Look below your brake master cylinder on the inner fender wall and spot a junction block for all the brake hydraulic lines. On top in the middle should be a electrical post - your wire goes there. As I recall, this is a low fluid/pressure sensor and will cause the e-brake light on your dash to light. Link to comment https://www.classiczcars.com/forums/topic/47956-73-240z-yellow-and-green-wire-coming-from-the-winshield-washer-wire-bundle/#findComment-436024 Share on other sites More sharing options...
November 14, 201311 yr Author comment_436092 jfa.series1 said: Look below your brake master cylinder on the inner fender wall and spot a junction block for all the brake hydraulic lines. On top in the middle should be a electrical post - your wire goes there. As I recall, this is a low fluid/pressure sensor and will cause the e-brake light on your dash to light.strong work bruu. it was exactly where you said it would be. thanks Link to comment https://www.classiczcars.com/forums/topic/47956-73-240z-yellow-and-green-wire-coming-from-the-winshield-washer-wire-bundle/#findComment-436092 Share on other sites More sharing options...
November 14, 201311 yr Author comment_436094 how about the solid green and solid black wires from the master cylinder caps? Which bundle of wires connects these two wires? Sorry, I got a hack job of a car. :-( Link to comment https://www.classiczcars.com/forums/topic/47956-73-240z-yellow-and-green-wire-coming-from-the-winshield-washer-wire-bundle/#findComment-436094 Share on other sites More sharing options...
November 14, 201311 yr comment_436107 It is possible that they are from a later ZX and in your'73 they are superfluous. On a ZX they hook up to warning sensors for low fluid.Cheers, Mike Link to comment https://www.classiczcars.com/forums/topic/47956-73-240z-yellow-and-green-wire-coming-from-the-winshield-washer-wire-bundle/#findComment-436107 Share on other sites More sharing options...
November 15, 201311 yr Author comment_436126 Pop said: It is possible that they are from a later ZX and in your'73 they are superfluous. On a ZX they hook up to warning sensors for low fluid.Cheers' date=' Mike[/quote']Long story short, cut them and make them disappear? Link to comment https://www.classiczcars.com/forums/topic/47956-73-240z-yellow-and-green-wire-coming-from-the-winshield-washer-wire-bundle/#findComment-436126 Share on other sites More sharing options...
November 17, 201311 yr comment_436258 That's a long story? Haha!! :laugh: Link to comment https://www.classiczcars.com/forums/topic/47956-73-240z-yellow-and-green-wire-coming-from-the-winshield-washer-wire-bundle/#findComment-436258 Share on other sites More sharing options...
