Email logins are now active ×
Oil pump/Distributor drive spindle won't insert all the way.
jwilliams905
Hi guys, So I had to change out my timing chain and tensioner. The tensioner went bad and the chain stretched. I've gotten it all installed and am now to the point of installing the Oil Pump and Distributor, along with the Drive Spindle. The problem is, I can't seem to get the spindle to go in all the way, not even far enough to run the oil pump bolts. Shouldn't be that hard, I would think. The engine is in TDC, and I'm installing the spindle short side out, 5 degrees clockwise from the distributor bolt holes. It wasn't this hard to pull it, I know for sure. Any help could be greatly appreciated!
It works with the damper and seal to keep oil from leaking. You can get to it rather easily if you think you may have put it on backwards. Pull the damper, pop out the seal and remove the slinger. If backwards, simply reinstall correctly, tap in a new seal and replace the damper. You should then be able to install the spindle easily.
  • Who's Online   2 Members, 0 Anonymous, 369 Guests (See full list)
